What springs are these? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-25-2015, 03:40 PM Thread Starter
i found these rear springs for sale on CL, and the guy doesnt know what exact spring it is. im assuming its pedders. he says they measure between 8, and 9 inches from top to bottom.. Im looking for 20mm drop springs. Any ideas? ( i added the pic as an attachment)
JoshLotterman is offline
post #2 of 5 (permalink) Old 11-25-2015, 04:19 PM
They are Pedders but wanting a 20mm drop with a guess of 8" or 9" isn't going to get you an accurate answer. I do have to say that I couldn't tell you though even if you did get a good measurement. Doesn't the guy know what they are?
post #3 of 5 (permalink) Old 11-25-2015, 04:52 PM Thread Starter
They were on the car when he bought it and he took them off because he was too low with 19 inch wheels. Is there a stamp on the spring anywhere? I attached a picture of his car with the springs installed and 19s.
post #4 of 5 (permalink) Old 11-26-2015, 10:47 PM
That's hard to tell. As far as I know there is no permanent marking. My Lovells just had a tag on them. From the picture it looks pretty low if that is a stock diameter tire. Pedders did make some that were an inch or more.
post #5 of 5 (permalink) Old 11-28-2015, 09:17 AM Thread Starter
Thank you for the input
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 09:52 PM
Stock Springs VS Lovells Springs GM4life Drive train, suspension, alignment and brakes. 10 06-03-2011 01:16 PM
Front Springs - What brand/spec springs are you running? Jeff's Classics 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 11-26-2010 12:12 PM
Where can i get springs for my 66 F-RICE 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-10-2009 07:49 PM
which springs M6GOAT Drive train, suspension, alignment and brakes. 3 02-02-2009 07:52 PM
