Wheel bearing replacement DIY - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-04-2013, 05:38 PM Thread Starter
Anyone have a link for a DIY on the front wheel bearings for an 05 GTO? Or a link for a free online factory service manual? I haven't had any luck locating a free service manual yet.
I went by Chevy today and they claim the front bearings only come as a pre-assembled hub unit with 2 tapered bearings inside for $450. Looking up parts at advance you can buy the separate bearings for about $13/each or a preassembled unit for about $150. It seems they are a typical tapered bearing with races and seals up front. Any reason I can't replace the bearings, races and seals at home?
05 GTO
Automatic
fishagto is offline
post #2 of 3 (permalink) Old 12-04-2013, 06:38 PM
Steamwalker's Avatar
The fronts are complete hub units. The rears can be replaced with just the bearings. The fronts are fairly easy. The rears are the tough ones.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 3 (permalink) Old 12-04-2013, 06:42 PM
06/QSM/A4
SoCal Goat Club
Rear Axle Bearing Replacement kenbaustin 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-06-2013 09:44 AM
Wheel Bearing Jeffcarr Service, Maintenance and Technical Discussion 2 01-02-2013 11:23 AM
Wheel Bearing Humming? chevyman2002 Service, Maintenance and Technical Discussion 6 06-11-2012 07:27 PM
64 Axle Bearing Replacement Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 05-10-2012 04:57 PM
wheel bearing nut Topkat 1964-1974 Tempest, Lemans & GTO Wheels & Tires 6 04-05-2011 03:50 AM
