Yet another clunk - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-27-2006, 04:31 PM Thread Starter
Yet another clunk
Forgive me... I have searched... and I can't quite find what I would consider to be exactly what I am experiencing.
When I make a sharp right turn, at an incline (Example: Every single time I turn right into a driveway.... not left!.... just right) I here a distinct thunk or clunk or whatever from the right rear ( I think it's the right but I know it's the rear) of my car.
The dealer claims to not hear it (which is infuriating because it's both loud and consistent) and so I am left with the question of what to do about it.
I would appreciate any insight that anyone might have.
Thanks.
tano is offline
post #2 of 6 (permalink) Old 09-27-2006, 09:56 PM
Holden's Avatar
Sway Bar Link Bushings! They are bad from build, very bad setup. There should be a small joint there but they just put bushings. I first tightend mine caz Dealer cant hear anything ever. I have aftermarket ones on order now hope that helps.
Holden is offline
post #3 of 6 (permalink) Old 09-28-2006, 12:49 PM Thread Starter
So.... you've got the same thing? Same side? Is it potentially a serious issue or is it just the annyance of the noise?
Let me know if the aftermarket product resolves!
Thanks.
tano is offline
post #4 of 6 (permalink) Old 09-28-2006, 05:56 PM
My control links did the same thing. Working on getting a complete setup from Pedders now. Factory front suspensions on these cars leave alot to be desired.
shelbytwpgoat is offline
post #5 of 6 (permalink) Old 09-28-2006, 07:58 PM
Holden's Avatar
There is no fix for this setup, the bushings rotate every time strut turns. I dont know why they didnt put small joint like on other end and on most cars and vans. May be a performance thing just looks cheap to me. I will post about bushings they were backordred. I ordred drag bags same time and one of thoes leaks
Holden is offline
post #6 of 6 (permalink) Old 10-01-2006, 03:33 PM
Gpr1200r's Avatar
Ditto...same problem here.......Gm tech support...where are you ?????
THIS SITE ROCKS.....IN A SAMMY HAGAR SORT OF WAY......PEACE OUT......GPR1200R
Gpr1200r is offline
