04-06 brake conversion - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-02-2012, 06:32 PM Thread Starter
Papa Rad's Avatar
what all is needed to convert the 04 brakes to bigger 05-06?
Difflow diffuser, K&N intake, x pipe only exhaust, HO alternator, pioneer touch screen, 55w HID's, 35w fogs, halo/projector headlights, fender stripe, 5%-15% window tint, black lug nut caps, black side markers, more to come
Papa Rad is offline
post #2 of 8 (permalink) Old 06-02-2012, 08:35 PM
The Stamped's Avatar
I know you need like shims for the bolts. New rotors obviously. And new brake lines I believe. I'm thinkin of doin it myself soon. The 04 brakes just seem a bit weak. But there are other threds on this, so just search some more. N search on google too, I bet you'll find some threds on this on LS1gto too
The Stamped is offline
post #3 of 8 (permalink) Old 06-02-2012, 10:58 PM Thread Starter
Papa Rad's Avatar
what about the calipers? would ie be possible to just upgrade calipers and rotors? I wouldnt think anything else would need it but I'm new to the goat.
Papa Rad is offline
post #4 of 8 (permalink) Old 06-03-2012, 09:01 AM
Calipers and rotors are the conversion but you need brake lines and bushings with new bolts to mount them to the car. I got my rotors/calipers from Cleveland Pick-a-part and was surprised that the rotors came already turned and looking near new. I got Russel brake lines and C5 Corvette ceramic pads from Maryland Speed and bushings and bolts from McMaster. The bushings are one of two things you can do. The '05-'06 are mounted with bigger bolts and you can either drill and retap your mounting place or use the '04 stock sized bolt and use the bushing to adapt to the hole in the caliper. It's a pretty straight forward job..
post #5 of 8 (permalink) Old 06-04-2012, 02:35 AM
exCTLY!!
tlillard23 is offline
post #6 of 8 (permalink) Old 06-04-2012, 10:47 PM Thread Starter
Papa Rad's Avatar
would there be any way to just get new fittings for the lines instead of running whole new ones?
Papa Rad is offline
post #7 of 8 (permalink) Old 06-05-2012, 01:53 PM
jpalamar's Avatar
I'd rather have upgraded 04 pads/rotors then stock 05/06 brakes... but if you plan on going with better rotors and pads with the 05/06 its def worth it.
04 GTO - sold
jpalamar is offline
post #8 of 8 (permalink) Old 06-05-2012, 04:11 PM Thread Starter
Papa Rad's Avatar
upgraded as in drilled and slotted? or something else?
Papa Rad is offline
68 disc brake conversion Black68GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 17 06-11-2018 08:46 PM
Disc Brake Conversion sixeightGTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 08-25-2010 12:30 PM
Disc Brake Conversion OrbitOrange 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 20 07-31-2010 01:59 PM
Need help with brake conversion Bensjammin66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 12-28-2009 09:31 PM
Disc brake conversion squeezedgto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 10-31-2006 04:25 PM
