15" pro star's on a 06 - Pontiac GTO Forum
post #1 of 13 (permalink) Old 06-04-2011, 09:18 PM Thread Starter
lowpro192000's Avatar
I have an 06 and was wondering if i could run 15" pro stars all the way around. I test fitted a set of billet specitallies off my buddies camaro but we werent sure of the off set , and i have no idea what kind of off set i would need on some pro stars. the fronts fit but i had to put like a quarter inch spacer on it to clear the calipers. any info would be helpful and im pretty sure it can be done because ive seen pictures of gtos with thme on it
lowpro192000 is offline
post #2 of 13 (permalink) Old 06-04-2011, 10:27 PM
Depends on the width and it you have stock or aftermarket brakes. 10" wide rears are usually in the 7Ĺ" backspace range. As you found out the brakes are an issues with smaller diameter rims.
post #3 of 13 (permalink) Old 06-04-2011, 11:42 PM Thread Starter
I have stock brakes and i was thinking about going either 15x8 or 15x10's out back and runing like a 15x3.5 or 15x4 in the front. its gonna be a track setup
post #4 of 13 (permalink) Old 06-06-2011, 06:17 PM
Narrow fronts should work fine as even if you had a clearance problem all you'd have to do is put spacers on.
post #5 of 13 (permalink) Old 06-27-2011, 09:32 AM
will a 15x10 fit under the rear? im wanting to get a set of prostars also and im thinking a 15x10 as long as it clears
04black is offline
post #6 of 13 (permalink) Old 06-27-2011, 11:23 AM
They can fit but it may take some work and a 7 1/2" backspace
post #7 of 13 (permalink) Old 06-27-2011, 12:49 PM
Would a 15x8 be more practical then? With say a 6 1/2 to 7 backspace
04black is offline
post #8 of 13 (permalink) Old 06-27-2011, 06:15 PM
Ya that would be a lot more of a sure thing. I'd also recommend getting the ARP Camaro/Corvette wheel studs. The stock ones are short and soft.
post #9 of 13 (permalink) Old 06-27-2011, 08:39 PM
how much longer are the arp studs because i have closed end spline lugs for my wheels
04black is offline
post #10 of 13 (permalink) Old 06-27-2011, 08:48 PM
They might work. The rears are fairly long but nothing like the replacement Evo ARP front ones are. If they're too long you just need to cut them shorter. I did that on mine all the way around. Wasn't that big of a deal.
67 Pro street Mr.Go-Goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 02-25-2012 05:44 AM
all pro heads? FIRELIFE25 Engine Discussions 0 08-11-2010 10:59 PM
Spare "tire"..better check it. "my lucky day" JWCACE Wheels and tires 0 05-17-2006 09:32 AM
Using the Gtech pro Joes04 Racing and Kill Forum 0 03-21-2006 06:16 PM
