18 Tire, Wheel, Springs Upgrade with Ride Height Pics Before and After - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-17-2014, 02:38 PM Thread Starter
JeffM's Avatar
My 2006 GTO has 48,000 miles on it. Under moderate acceleration, I was having horrible traction due to squatting. My rear tires were wearing on the inside edge really bad. It looked like my contact patch under acceleration was about as wide as a bicycle tire.
My rear ride height from the center of the hub to the lip of the fender was 13 . I installed Lovells 370mm springs with a 10mm spring pad and KYB shocks. This brought my height to 14 . I also had the rear fenders cut.
I have to agree with the other members that advised to pay particular attention to the offset. I found a great deal on Voxx Ferraro rims (18x8 40 offset fronts and 18x9 35 offset rears) and gambled with the rear offset. I have Nitto 245/40/18 on the front and bought 275/35/18 BFGoodrich g-Force Sport COMP-2 for the rear. I would like to have had a greater offset but, No tire rub and the traction is great!
Here is a great link to help with wheel offset and tire size: Tire Tech Information :: Wheel Size / Tire Calculator and Custom Offsets - Wheel-size.com
Name:	GTO Side Before Springs.jpg
ID:	36145   Click image for larger version
Name:	GTO Front Qtr Before Springs.jpg
ID:	36153   Click image for larger version
Name:	GTO REAR QTR After Springs.jpg
ID:	36161   Click image for larger version
Name:	GTO SIDE After Springs.jpg
ID:	36169   Click image for larger version
Name:	GTO REAR After Springs.jpg
2006, M6, LS2 Bottom, L92 Heads, 236/240 590/590 112 Cam, LS3 Intake, Ported Throttle body, Kooks Long tube, Cat less Flowmaster, Vararam, B&M Short Shifter, Centerforce Clutch, 439 whp/397 trq
JeffM is offline
post #2 of 6 (permalink) Old 03-18-2014, 05:10 AM
silversport's Avatar
pics looks nice...how's it feel when you drive???
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #3 of 6 (permalink) Old 03-18-2014, 05:28 AM Thread Starter
JeffM's Avatar
It drives and rides great. No more squatting and the ride quality is great (not stiff). I can accelerate fairly hard in 1st or second through a turn and it grips the road. before, it would fishtail and it was a unpredictable as hell. If you haven't changed springs, I would recommend it. I wasn't really sure if I needed to or not, but it has made a huge difference.
JeffM is offline
post #4 of 6 (permalink) Old 03-18-2014, 07:08 PM
pocketmaster's Avatar
I just installed 350mm Lovell's and love em. It sits almost exactly as your before pics. The squat is virtually eliminated. Love the ride and the quality of the Lovell's is spot on. Definitly worth the money!!
God Bless Billiards!!!!
pocketmaster is offline
post #5 of 6 (permalink) Old 03-20-2014, 06:56 PM
nice!! so the "after" is how the GTOs looked from the factory basically for a few thousands miles?
I bought my 2004 used in 2010 with 23k miles and can't even remember how it sat then. It is now however sitting a bit low in the rear. Almost looks like it has been lowered. I went ahead and ordered Lovells stock height rear springs.
i bought this (04-06 GTO NO RUB KIT) kit and hoping it will fix my inner tread wear on the front tires. I'm not sure if I should just go ahead and get struts too for the front..
Rgrafton is offline
post #6 of 6 (permalink) Old 03-23-2014, 12:42 AM
Steamwalker's Avatar
The rears are really known to sag so it creates an awful drop in the back compared to the front. I have stock height King springs in the rear with 8mm spring pads and it sits close to after pics here.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
Ride height question WhittP 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 34 01-31-2014 02:59 PM
Stock Ride Height GTOKID64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-24-2013 02:42 PM
'04 ride height question HalfWayOutTheDoor 2004-2006 GTO General Discussion 1 12-31-2010 05:08 AM
Ride height/ alignment bsmcall Service, Maintenance and Technical Discussion 0 05-22-2005 10:43 PM
