18" Staggered - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-11-2011, 06:06 PM Thread Starter
preach's Avatar
Send a message via MSN to preach
18" Staggered
I'm doing some research on a staggered 18" setup but the information in the sticky at the top makes me ???
Can someone explain why I would want a shorter sidewall on the front tires versus the rear as outlined in this piece of the sticky:
"18's
By far the best way to go!!
Front:
18x8 w/ a 245/40/18 tire - fit is perfect
18x8.5 w/ 255/40/18 - again sticks out too far
Rear:
18x9 w/ a 275/35/18 tire - fit is perfect
Recommendation for 18" wheels: Without a doubt the best set is 18x8 up front with 245/45/18 matched with 18x9 out back w/ 275/35/18. This set looks great, fits porportionally and lets you pick up some width out back. The ride quality is also great."
06 M6 CGM
preach is offline
post #2 of 5 (permalink) Old 10-11-2011, 08:24 PM
AlaGreyGoat's Avatar
Actually, a 245/40/18 and a 275/35/18 have about the same size sidewall and the same OD - 25.7 in and 25.6 in.
The sidewall numbers are ratios of the thread width to the sidewall size.
Larry
AlaGreyGoat is offline
post #3 of 5 (permalink) Old 10-11-2011, 09:11 PM Thread Starter
preach's Avatar
Ok. Since I don't have drag bags and I'm not doing any fender work I can't use 275's in the rear for fear of rubbing. (From what I've read/been told)
Assuming 265 is the widest I can go in the rear, should I go
Front: 245/40 tires (18x8 40 ET wheels)
Rear: 265/35 tires (18x9.5 45 ET wheels)
Or would there be a better tire combo for those wheels?
06 M6 CGM
preach is offline
post #4 of 5 (permalink) Old 10-23-2011, 08:14 AM
What are the offsets to this wheels? That will determine what tire size you can run without fender modifications.
1QWIK7 is offline
post #5 of 5 (permalink) Old 10-24-2011, 05:28 PM
Well the stock wheels are 48mm offset and 275s don't really fit in well on those so it would have to be greater than that. . . hard to do with most wheels
Srm on Asanti 18" 3 piece forged staggered.What you guys think so far?? nvr2fast Exterior Discussions 4 12-20-2007 07:29 PM
Axis Hiro 19" staggered txcharlie Wheels and tires 2 01-27-2007 11:52 AM
