18x9 rear wheel selection - Pontiac GTO Forum
post #1 of 22 (permalink) Old 11-10-2012, 03:36 AM Thread Starter
Giacobazzi's Avatar
I am doing new wheels and tires very soon and am seriously thinking bout the 18x9's in back with the 275's mentioned in the "wheel fitment" thread. My Q is what are my offset tolerances that I can do on that back wheel, and what are my choices in wheel style. When i do a search, I don't see many 18x9's in an offset that I would need, at least not on tire rack, and a few other wheel suppliers. Also I'm not gonna spend mega $ for this. I see wheels I like for $135-$185 per wheel, but in 18x8. Where should I be looking?
Thanks!
Giaco
Giacobazzi is offline
post #2 of 22 (permalink) Old 11-10-2012, 08:11 AM
Ideally you'd like to be in the mid +50s offset. Depending on how aggressively you roll or cut the fenders and tire width (different brands are different widths of the same "size") you could go down to +40. There are only a handful of wheels that fit that definition without going custom.
post #3 of 22 (permalink) Old 11-10-2012, 10:24 AM Thread Starter
Giacobazzi's Avatar
Here is the fitment info I was referring to. Was on another forum. Anyway if its too difficult, like price or availability, I will just do the 245/40/18's all around. But alota beef out back is always tuff looking
Factory wheels & tires:
17x8 w/ 245/45/17
55lbs each (wheel & tire)
5x120mm stud pattern
48mm backspacing
17's
Front:
245/45/17 is still the best fit
255/40/17 fit but had to use a 8.5" wide wheel, the required backspacing hadthe wheels/tire sticking out too from the body line
275/40/17 didn't fit, using a 9" wide wheel, the tire was rubbibg the strut. Again using a different backspacing would have the set sticking out too far
ROH Drift R 17x8 w/ 245/45/17 - 47lbs
ROH Drift R 17x9 w/275/40/17 - 49lbs
Rear:
275/40/17 fit no problems on a 17x9" wheel
These stick out just a little more than the factory tires, but I think they still look great!
Recommendation for 17" wheels: Use your factory tires and and put them on 17x8" custom wheels or 17x8" wheel front w/ 245/45/17 tires and 17x9" wheel rear w/ 275/40/17 tires
Personally I would just reuse the factory tires and put 17x8" wheels at all four corners. This will be cheaper to do and looks good.
18's
By far the best way to go!!
Front:
18x8 w/ a 245/40/18 tire - fit is perfect
18x8.5 w/ 255/40/18 - again sticks out too far
Rear:
18x9 w/ a 275/35/18 tire - fit is perfect
Recommendation for 18" wheels: Without a doubt the best set is 18x8 up front with 245/45/18 matched with 18x9 out back w/ 275/35/18. This set looks great, fits porportionally and lets you pick up some width out back. The ride quality is also great. Or use 18x8 and 245/40/18 at all four corners.
ROH Drift R 18x8 w/ a 245/40/18 tire - 49lbs
ROH Drift R 18x9 w/ a 275/35/18 tire - 51lbs
19's
Front
245/35/19 on a 19x8" wheel
Rear
275/30/19 on a 19x9" wheel
Recommendation for 19" wheels: GO BACK TO 18"!! While the look great on the car the ride quality is horrible. If you could care less about feeling every bump in the road and want all the look, these are for you. If you just gotta have them then use 19x8 w/ 245/35/19 front and 19x9 w/ 275/35/19 rear or the 19x9 w/ 245/35/19 all the way around.
Giaco
post #4 of 22 (permalink) Old 02-20-2013, 01:53 AM
blackwidow's Avatar
Was hoping to get 18" by 9" all the way around on my ride...do you think wider wheels would work with aftermarket, smaller diameter struts up front and inboard-mounted coils out back?
blackwidow is offline
post #5 of 22 (permalink) Old 02-26-2013, 10:20 PM
Steamwalker's Avatar
18x9s with +45 offset on my rear with 265s on them. Fender mildly cut. If I rolled the fenders or cut more of the fender, I'd easily fit 275s back there, no problem. Not lowered here at all though.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #6 of 22 (permalink) Old 02-27-2013, 05:45 PM
9" on the front would be hard to do right. It isn't just the strut but also the wheel well because you're turning the wheels unlike the back. If you go with 18x8 front and 18x9 back with the back's offset 45-55 you would be pretty safe and be able to put meatier tires back there effectively.
post #7 of 22 (permalink) Old 03-04-2013, 02:28 PM
blackwidow's Avatar
would an 18x8 be too narrow for a 255? most tire sites recommend an 8.5 - 10, but its only a half inch...
post #8 of 22 (permalink) Old 03-04-2013, 06:29 PM
Honestly, you are not going to see any benefit running a 255 on an 18x8 than a 245 on an 18x8.
06/QSM/A4
SoCal Goat Club
post #9 of 22 (permalink) Old 03-05-2013, 09:08 AM
The only benefit you see is with certain brands. Nittos for instance are a size smaller than BFGs. I went up a size going to Nitto to keep the same tread on the ground as my "smaller" old tires
post #10 of 22 (permalink) Old 03-05-2013, 12:27 PM
blackwidow's Avatar
ever heard anybody running the hankook ventus v12 evo's? do these tend to run wide or narrow? These are what i'm putting on the goat...got 285/35/18 for the rear, and looking at 255/40/18 or 255/35/18 for the front.
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
Fitment on ARC-8 18x9" Wheel DementedSix0 Wheels and tires 9 06-09-2012 07:55 PM
HELP!!! 18x9" with +38 offset fit on REAR?? GTOFEVR Wheels and tires 6 04-14-2010 11:44 AM
Need help with cam selection biffman Engine Discussions 16 10-01-2009 08:10 AM
