19" BMW 745i wheels on GTO - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-27-2011, 06:50 PM Thread Starter
I was wondering if you guys know if the BMW 745i wheels would fit the Goat.
These are the wheels I am talking about:
Bmw 7 Series 2002-2008 19x10 Black Chrome Factory Replacement Wheels - ALY59399U87N
they are 5X120 which is the same lug pattern as the GTO but not quit sure about the offset and if it would rub since they are much bigger..
thanks
Alireza is offline
post #2 of 6 (permalink) Old 05-28-2011, 10:42 PM
im working to fit my 18 285/35 into the rear, it is fitting but space is so hard to find, if you get my point, my fender lips are flat with the fender, and i'll be able to fit it in. now if you want 19 you will have to cut the lips.
19 it is possible but your tires will have to be very low profile, which means you will be sacraficing traction. go with 18 and put more rubber on the tire for better performance.
firebird is offline
post #3 of 6 (permalink) Old 05-28-2011, 10:44 PM
oh yeah and you will need to spend money on stiffer springs in the back as well as stock will squat down so much that you might be rubbing big time
firebird is offline
post #4 of 6 (permalink) Old 05-29-2011, 05:56 PM
Squat shouldn't matter for fit. If it fits then you should be able to go to the bump stops without rubbing. Jacking the car up or having such a stiff suspension that it can't squat down if needed is a bandaid and will make for poor ride and handling. For a guess on those wheels you'd need to find the offset
post #5 of 6 (permalink) Old 05-29-2011, 08:09 PM
it will make the car handle good with stiffer springs. one of the reasons people change from oem, but you know that already lol. on the other hand, you're right, 19 with the right tire and the squat wont matter but then again wont have the full benefits from the car. and, even if he adjusts the camber to tilt the wheels in, he will get the traction once the inside wears out a bit and seats in with the rest of the tire, mid to outter part.
firebird is offline
post #6 of 6 (permalink) Old 05-30-2011, 01:33 PM
They won't work the offsets are too low. (+25 to +19) range.
04 A4 PBM
297WHP 315WTQ
ENUF PWR is offline
Pics of BMW wheels on GTO? Anyone? AmeliaGoat Wheels and tires 5 12-09-2010 03:07 PM
bmw wheels on gto luisgt13 1964-1974 Tempest, Lemans & GTO Wheels & Tires 20 09-01-2010 08:33 AM
wheels off a BMW will they fit? GoatOnMeth Wheels and tires 3 06-11-2009 02:29 PM
bmw wheels dent Wheels and tires 5 03-30-2009 11:10 PM
BMW wheels and Pontiac wheel centers toolman 2004-2006 GTO General Discussion 88 07-03-2005 11:02 AM
