1965 Gto Wheel and tire Help! - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-24-2018, 12:51 PM Thread Starter
I'm finally on the homestretch with MY 65 gto resto, and I'm shopping for a 18x8 Front 18x9 rear rim setup, I think I'm going with the ridler 850 rims but need help on sizing the tires anyone have a similar rim size that has fitted tires that can help? Thanks in advance
Abeling11 is offline
post #2 of 5 (permalink) Old 12-24-2018, 07:40 PM
RMTZ67's Avatar
Quoted: 64 Post(s)
Is it ridler 650 like the ones on my car? Look at my garage then look at my wheels. I have 17x8 all the way around. 255/40/17 in the rear.225/40/17 on the front. I did have 17x9.5 of another type in the rear with 4.5 offset. My current 17x8 with 4.5 offset is about a 1/4 from touching the lower fender by the moulding.
RMTZ67 is online now
post #3 of 5 (permalink) Old 12-24-2018, 07:56 PM
RMTZ67's Avatar
Quoted: 64 Post(s)
Could not figure out how to edit from my phone. But the front is the one that was close to rubbing when I turn. The prior 17x9.5 would rub on the tears even with some modification on the inner feeder well if you know what I mean.
post #4 of 5 (permalink) Old 12-24-2018, 08:48 PM
Quoted: 129 Post(s)
Not 18", but will give you an idea...
This is what I am running: 245/45/17 front & 274/40/17 rear on American Racing Torque Thrust II. The wheels are American Racing Torque Thrust II (polished) 17x8 (front) & 17x9.5 (rear). The tires are BFG GForce Sport C2. So far I like how the tires perform.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 5 (permalink) Old 01-27-2019, 01:02 PM
Briankdau's Avatar
Could you possibly post a picture of yr car when you have time
Briankdau is offline
1965 GTO wheel and tire upgrade wkidgto 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 08-28-2018 10:12 AM
Front wheel and tire fitment and trunk pan question Alaska GTO 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 04-22-2014 05:02 PM
What wheel and tire sizes i can fit on my 06 and where to find them??? Hanks06gto Wheels and tires 5 03-05-2007 08:47 PM
1965 Gto Tire/wheel Size DT65 1964-1974 Tempest, Lemans & GTO Wheels & Tires 6 10-13-2004 11:22 AM
