235-55-17 on my GTO - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-09-2011, 10:36 PM Thread Starter
danfigg's Avatar
235-55-17 on my GTO
I put a set of goodyear brand 235-55-17 on my GTO they are 27.20 inches tall and fit nicely. No more wheel spin as with the 245"s and the acceleration it great. There is an obvious gear ratio change with this tire Im guessing in 3.30 range but the car seems to like it. I will do some drag strip test soon. Im curious as to how this gear change will affect my ET's my last run was 13.27 at 106 so Im thinking I will have a slower ET but a higher MPH. I saw this size tire on the newer style Mustangs and figured since the price was right $50.00 for both I would give them a try.-----Danfigg
danfigg is offline
post #2 of 8 (permalink) Old 06-10-2011, 12:00 PM
Interesting idea. Your speed should be off about 5% (indicated lower than actual) and your gearing is around an effective 3.28 instead of 3.46. You actually lost a small amount of contact patch and may have a better launch due to the gearing change preventing you from spinning and differing rubber compound may explain differences as well. I commented on my 3.46 gears both helping and hurting as it makes it too easy to spin on launch. The higher sidewall can help cushion the "shock" as well.
post #3 of 8 (permalink) Old 06-10-2011, 06:34 PM Thread Starter
danfigg's Avatar
re
Svede you hit it on the head that is why I thought of trying this. Not much change in handling, and the rake is some what interesting I will try to post some pics soon. I will also try them on the front to see if they fit as well.The tire seems to be wider as you look from the back but according to tire rack the 235-55-17 are 9.7" 8.1" 27.2" 769---the 245-45-17 are 9.4" 8.3" 25.8" 808
section width -tread width -overall diameter -REV per Mile
danfigg is offline
post #4 of 8 (permalink) Old 06-10-2011, 06:36 PM Thread Starter
danfigg's Avatar
re
Just checked the 235 -50 -17 is a better fit its wider 9.7" 8.5" 26.3" 792
danfigg is offline
post #5 of 8 (permalink) Old 06-10-2011, 09:18 PM
Check this out . . . "this"
post #6 of 8 (permalink) Old 06-10-2011, 10:47 PM
87GN06GTO07IRL's Avatar
^^^great find Svede! One of the best i've seen.
87GN06GTO07IRL is offline
post #7 of 8 (permalink) Old 06-10-2011, 11:24 PM
Google is evil. . . and my friend
post #8 of 8 (permalink) Old 06-11-2011, 02:47 PM
Rainmans 05's Avatar
Web searches are a wonderful thing...
2005 Torrid Red/Black M6 GTO
1 of 641
Rainmans 05 is offline
235/45/17 bwhit Wheels and tires 1 07-27-2009 05:41 PM
235/40/17 on stock 17" NT91 Wheels and tires 6 04-19-2008 08:00 AM
POTENZA 235/40 18Ē Stock Holden 2004-2006 GTO General Discussion 3 10-22-2005 08:55 PM
