BMW Wheels - ASA Wheels for 05 M3 on 05 GTO? - Pontiac GTO Forum
post #1 of 10 (permalink) Old 01-28-2012, 01:28 AM Thread Starter
noel the legend's Avatar
I'm hoping someone can give a definitive answer, as I've been unable to find one in my searching on the BMW/GTO wheel fitment issue.
I'm looking at a set of ASA GT5 Wheels from a 05 M3. It is a staggered set-up. Fitment:
FRONT 18x8
Offset: 40mm
Backspacing: 6.10"
Bolt-Pattern: 5-120 (I know this is what we need, but is 5-120 universal, or, like everything else with the GTO, is there something different that makes it non-compatable?)
REAR 18x9
Offset: +30mm
Backspacing: 6.22"
Bolt Pattern: 5-120
My main reason for asking is that Tire Rack (where I found the wheels in question) seems to offer the best wheel/tire price and I can order them pre-mounted and balanced. If I can run this set-up, I think this is what I'll spring for.
I will be having my Pedders Street 2 installed in the beginning of February. This is the NO drop Kit, so I will retain OEM height.
Will this fit? If not, is there anything that can be done to make it fit? i.e., spacers, etc. I do not want to roll my fenders.
Thanks for the input ahead of time.
I've never "taken a s*** because getting it out of the toilet would be disgusting. - Me
noel the legend is offline
post #2 of 10 (permalink) Old 01-29-2012, 11:33 PM Thread Starter
Any help?
post #3 of 10 (permalink) Old 01-31-2012, 08:31 PM
87GN06GTO07IRL's Avatar
If you want help your going to need to list the wheel width and the tire size.
87GN06GTO07IRL is offline
post #4 of 10 (permalink) Old 02-02-2012, 07:49 AM Thread Starter
Ha! I was so concerned about posting the backspacing I forgot to put that. Thanks. Front are 18x8 and rear are 18x9.
post #5 of 10 (permalink) Old 02-10-2012, 07:34 AM
Rear would require quarter modifications.
tleroy is offline
post #6 of 10 (permalink) Old 02-10-2012, 10:34 PM Thread Starter
I found 18x9 rears for an 05 330 coupe with 45mm backspacing. Guy at the tire rack says he had a GTO (2006) and that he had BMW 330 ASAs on. Will moving from a 30mm to 45mm backspace make it doable?
post #7 of 10 (permalink) Old 03-04-2012, 08:07 PM
MBM GTO's Avatar
I know 45 for the rears would be good with a 9 inch rim.
MBM GTO is offline
post #8 of 10 (permalink) Old 03-05-2012, 04:14 AM Thread Starter
I ended up getting the Enki Tuning Rijian Black painted wheels. I liked the look better, they were a tad cheaper, a bit lighter an I an rotate. I have 245/40 Hankook Ventus V12 evos on them. I think my other wheels (aftermarket, but idk what...) were heavy POSs. I could feel a significant difference (plus better rubber helps). The ones I took off were heeeeeavy, man.
I have pics posted under the tread "Enki Tuning...blah, blah, blah"
I can't seem to be able to take a pic that captures how good they look, but I love em. They are listed on TireRack under 2005 BMW 330, if interested.
I'm DDing my Goat for now...if I wasn't, I'd probably be running a staggered. Either way, I can't be happier. Next go 'round, I'm gonna run 255/35s. I have good clearance, so the extra 5mm per side will be good.
post #9 of 10 (permalink) Old 03-05-2012, 10:10 AM
Pics!
Sent from my Autoguide iPhone app
Texanfan392 is offline
post #10 of 10 (permalink) Old 03-06-2012, 07:52 AM Thread Starter
https://www.gtoforum.com/f40/18-enkei...painted-36662/
Pics on this thread.
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
New wheels! deaner17 Wheels and tires 3 08-09-2009 08:42 PM
wheels REDGTO89 Wheels and tires 2 01-23-2009 10:07 AM
C5 wheels on GTO jryt Service, Maintenance and Technical Discussion 5 09-16-2005 09:00 PM
