Factory wheel discoloration and hairline cracks - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-31-2012, 12:14 AM Thread Starter
Aspired's Avatar
2005 with factory 17's - never seen winter or salt
Drivers rear wheel has discolored and looks light gold in comparison to other 4 wheels. It also has a bunch of little cracks like it has a clear or protective coating that is failing if your up close to it.
I cleaned it with wheel cleaner many times and no change.
Is there a coating on the wheels and what is it?
Anyone know what the issue might be, if this is common (must not be as I couldn't find anything in forums on)
Also looking for a way to fix myself or place hopefully in MN to get it refinished?
Might be cheaper to just buy a used on but mine is fine other wise and I prefer to not be wasteful.
Thanks for your time!
Aspired is offline
post #2 of 5 (permalink) Old 03-31-2012, 07:32 AM
silversport's Avatar
factory 17s are painted alloy...(probably clear coated as well)...usually when I see the goldish color it is from brake dust that wasn't removed (can be corrosive) and some wheel cleaners, especially when put on a warm or hot wheel can etch the finish...
If one of these is your issue, the wheel refinisher should be able to fix you up for not a real lot of cash...good luck and let us know the outcome...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #3 of 5 (permalink) Old 03-31-2012, 12:26 PM Thread Starter
Aspired's Avatar
Ok so painted and then cleared - good info!
Now I have something to work off, I'll make some calls this week.
Side notes:
Wheels are always cleaned with Turtles Wax Ice car wash when I wash the car and never have left brake dust on. Only used Mother Tire car wash after discoloration issue started which I like for my truck rims. Yeah some stuff it to abrasive.
I did get some salt slush on the wheel last winter in the garage it was parked next to my truck and I stepped in some slush pile that fell of the truck and splashed that rim and tire only, I washed it off immediately with water but can only figure that caused the issue if it is a painted finish.
Thanks!
Aspired is offline
post #4 of 5 (permalink) Old 04-01-2012, 12:02 AM Thread Starter
Aspired's Avatar
Have a line into AWRS local rep
Do mobile repair so maybe they can do it while I am at work this week
Aspired is offline
post #5 of 5 (permalink) Old 04-03-2012, 10:40 AM
jpalamar's Avatar
Thanks!
I drove my car through several winters and rarely washed it when it was cold. My wheels didn't have these issues. Sounds like a factory defect.
Eitherway, I'd get them powdercoated. Probally will cost the same as having somone come out and do an 'okay' job on site.
jpalamar is offline
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
Which wheel raspantienator Wheels and tires 20 07-14-2009 07:19 AM
Wheel hop??? 05_HUMBLER 2004-2006 GTO General Discussion 7 12-19-2005 08:28 AM
Wheel Hop-Help MARS Service, Maintenance and Technical Discussion 8 02-17-2005 08:47 AM
Need wheel help roadracer 2004-2006 GTO General Discussion 15 02-02-2005 07:44 PM
