HELP... RIM & TIRE setup? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-03-2012, 01:16 PM Thread Starter
I have a 06 M6 Goat I have been following chats about rim and tire sizes for the Goat for about two weeks. Im lookin for some info on Black Rims and the proper tire size I can instal with out fender rolling etc. If someone has some answers for me that would be sooo helpful. If ya have pictures of your Goat with Black Paint with Black Rims you would be simply awesome.
Murph
Wha happened she said as I slapped it in 3rd gear!
hotrodd is offline
post #2 of 4 (permalink) Old 05-18-2012, 08:27 PM
ULTIMATE PONTIAC GTO PICTURE SITE Text Topics article #29
Follow this link. Put in your year model. I hope it answers your question.
cdslayer1 is offline
post #3 of 4 (permalink) Old 05-29-2012, 12:54 AM
noel the legend's Avatar
I bought my wheels from TireRack.com. I'm sure you have been there already. I'm sure you have seen that there are limited selections for the GTO b/c of the 5x120 bolt pattern.
Try it again, only select a 2005 BMW 330. The bolt pattern is the same. I ended up going with Enkei Tuning Raijin Black Painted Wheels (18x8, Offset: 42 mm, Backspacing: 6.06). They fit just fine. I do have the Pedders Street II package, which addresses the tire rub that is common with the GTO, but you should still be fine. I mounted Hankook Ventus V12 evo 245/40 rubber onto the wheels. Next time I get rubber, I'm going to run 255/35, as I have plenty of room.
I've never "taken a s*** because getting it out of the toilet would be disgusting. - Me
noel the legend is offline
post #4 of 4 (permalink) Old 05-29-2012, 10:50 AM
If you go non-GTO specific wheels make sure to get the proper sized hub ring if it's necessary. The biggest problem outside of that is a lot of people don't get a wheel with enough back spacing (stock is 48mm on a 8" rim) and end up having to use small tires, have rubbing or need to jack up the back end like a 4x4. The wider the rim you should add about half the increase over 8" (12.7mm) to the 48mm back space to be perfect. You can vary a little on back space from ideal but it's easiest to fit the biggest tire with it being close. Too much is always preferable to too little.
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
Just got back from tire shop, 15x7 275/60/15 Max tire? HELP! GreenMachine 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-20-2010 05:33 PM
What's your alignment settings for your suspension and wheel/tire setup? batmans Drive train, suspension, alignment and brakes. 4 03-17-2010 11:05 AM
What do you think of this setup? YeloTXGoat38 Drive train, suspension, alignment and brakes. 1 08-31-2007 11:50 AM
Suspension Airbag Setup Vs. Regular Suspension Setup MJGTOWISH 2004-2006 GTO General Discussion 8 06-20-2006 09:23 AM
