how wide can i go with stock rims - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-06-2011, 03:38 PM Thread Starter
GTOMOE9's Avatar
i need to get some new tires for the rear and i want to get something a little wider than 235s how wide can i go with the stock rims
Spintech H-Pipe/Kooks SS Catless Mids/New Era Intake/MS4 111 LSA/Ported TB/160 Stat/Monster Stage 3/LSS
GTOMOE9 is offline
post #2 of 4 (permalink) Old 09-06-2011, 04:09 PM
Stock 18's I have 265/35 on rear no problems. Diameter of 265/35 and 235/40(front) is identical so you won't have any issues with height difference
Mddrummer911 is offline
post #3 of 4 (permalink) Old 09-06-2011, 04:32 PM
Falco21's Avatar
Here is a good read on that:
Wheel & tire fitting results!! - LS1GTO.com Forums
"If you want more inches.....STROKE IT!!"
Falco21 is offline
post #4 of 4 (permalink) Old 09-06-2011, 05:22 PM
87GN06GTO07IRL's Avatar
245 is the max width recommended for an eight inch wheel. You can cram a wider tire on but will have a reduced contact patch.
87GN06GTO07IRL is offline
