I need wheel spacers - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-20-2013, 09:44 PM Thread Starter
If anyone can help I need 5mm wheel spacers. Any one know where I can find them? Thanks
11bravogoat is offline
post #2 of 7 (permalink) Old 09-21-2013, 03:06 PM
I believe Summit has them. You'll have to use a BMW set and the hub bore is larger but that shouldn't make any difference as you'll have enough hub sticking out for wheel support. We have 120mm lug spacing. I had a set custom made years ago with the right hub bore and they were fairly expensive.
post #3 of 7 (permalink) Old 09-21-2013, 04:59 PM
SANDU002's Avatar
Got mine from Summit.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 7 (permalink) Old 09-21-2013, 06:54 PM Thread Starter
Thank you
post #5 of 7 (permalink) Old 09-22-2013, 02:25 PM
FWIW I would strongly suggest upgrading the wheel studs to ARP. The stock rears are shorter than the front and are pretty soft and weak. The fronts use EVO studs and the rears use Corvette/Camaro ones. They should be cut down a little as they will be too long without doing that. Pair those with some nice closed end tuner lug nuts to replace the cheap plastic covered ones and you'll have a nice upgrade.
post #6 of 7 (permalink) Old 09-23-2013, 07:05 AM
SANDU002's Avatar
Svede is right about the ARP wheel studs. When you put the spacers on, you will be glad you have that extra threading for the lug nuts.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #7 of 7 (permalink) Old 09-23-2013, 10:53 PM Thread Starter
Thanks guys
spacers on upper a arms ? 67RestoTempest 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 07-25-2013 01:35 PM
1" rear spacers Papa Rad Wheels and tires 9 11-27-2012 09:06 PM
Carb spacers Chris Holabaugh 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-28-2012 12:37 PM
Need help with Rim Spacers bradleygto Wheels and tires 1 12-19-2009 01:09 PM
Wheel spacers to fix rubbing issue? Freebs Wheels and tires 32 11-06-2009 01:58 PM
