Ideal Aftermarket Wheel Offset - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-17-2014, 06:35 PM Thread Starter
First post here, looking for some info for ideal fitments for offset on aftermarket wheels. I am looking to fill the rear wheel wells in more but still have room for suspension travel. I am running coilovers and can adjust height as necessary. Any help is appreciated!
vwpat is offline
post #2 of 5 (permalink) Old 04-18-2014, 01:49 PM
Height of the car has absolutely nothing to do with fitment. The width will determine the best offset for a particular wheel.
post #3 of 5 (permalink) Old 04-18-2014, 03:32 PM
this is a much more complicated issue than most people initially realize.
you must measure to determine the backspacing required for your application.
once you know your backspacing, and have an idea how wide a tire you want to run, you can calculate offset.
if you're serious then i encourage you to do more research and try to get it right the first time.
a quick google search on this topic will get you on the right track.
there are quite a few videos on you tube which will help you.
good luck!
1968 GTO Resto-Mod is offline
post #4 of 5 (permalink) Old 04-18-2014, 10:12 PM
It's fairly easy as the offset is well established for our cars. The absolute max width wheel without a minitub is a 10" wheel. 9 to 9 1/2" is easier to do. With aftermarket wheels with the correct 120mm lug spacing there are few options compared to other cars. Anything over a 50mm offset (a 10" wide wheel would be better with more) and fender cutting or rolling is necessary. My car for instance has 9" wide rear wheels with a 56mm offset. With that a mild fender roll and minor "hammer adjustment" of the inner fender gives clearance even with the car squatting to the bump stops or hard cornering
post #5 of 5 (permalink) Old 06-03-2014, 07:49 AM
JeffM's Avatar
https://www.gtoforum.com/f40/18-tire-...53/#post484233
This is a good site that you can play with different offsets Tire Tech Information :: Wheel Size / Tire Calculator and Custom Offsets - Wheel-size.com
2006, M6, LS2 Bottom, L92 Heads, 236/240 590/590 112 Cam, LS3 Intake, Ported Throttle body, Kooks Long tube, Cat less Flowmaster, Vararam, B&M Short Shifter, Centerforce Clutch, 439 whp/397 trq
JeffM is offline
VMR wheel offset charlied8 Wheels and tires 7 04-18-2010 10:30 PM
IS there a 17'' 48mm offset aftermarket wheel? Cobra126 Wheels and tires 11 10-14-2009 12:00 AM
Ideal offset for recommended fitment BlackPearl Wheels and tires 2 09-13-2006 09:20 AM
