Larger meats - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-06-2012, 12:04 PM Thread Starter
Larger meats
Looking to put larger tires in the rear. I heard that you can fit 285's with a fender roll with the stock suspension. Im a noobie when it comes to wheel spacing and all that jazz. Just want some input on what works. Thanks!
Sent from my Autoguide iPhone app
GtoGo677 is offline
post #2 of 2 (permalink) Old 06-06-2012, 06:38 PM
I have 285s on a 3/4" drop and rolled fenders. IMHO inner and outer control arm bushing help hold the control arm from lateral movement on corners. I had my stock wheels widened an inch and then used wheel spacers to make an effective ~55mm offset. The wider wheel also keeps the tire from bulging at the sides from too small of a wheel and helps get a good contact patch on the ground. Mild rolling of the fenders and I can hit the bump stops without any rubbing.
El Camino Rumored to Return as Part of GM's Larger RWD Plan AutoGuide.com In the News 17 01-04-2011 01:43 AM
Report: Chevy Cruze Coupe, Larger RWD Sedan Likely Says GM's New President Administrator In the News 1 03-11-2010 01:03 PM
