A new set of wheels - Pontiac GTO Forum
post #1 of 10 (permalink) Old 03-10-2012, 12:51 AM Thread Starter
AlanSr's Avatar
A new set of wheels
Sorry I can't remember the name of them.
When I bought them online I thought they were going to have a deeper lip but overall I'm happy with the aggressive look they have.
ID:	14192   Click image for larger version
ID:	14193   Click image for larger version
ID:	14194   Click image for larger version
AlanSr is offline
post #2 of 10 (permalink) Old 03-10-2012, 12:55 AM Thread Starter
AlanSr's Avatar
Next thing I wanted to do was drop it a inch but I think the wheels might be a little to wide to drop it.
AlanSr is offline
post #3 of 10 (permalink) Old 03-26-2012, 11:42 AM
what size tires are those?
gtogooch is offline
post #4 of 10 (permalink) Old 03-27-2012, 04:17 PM
Those look good on that color. Your car does look high tho. What's the tire size and offset and width of those wheels.
post #5 of 10 (permalink) Old 03-30-2012, 01:41 AM Thread Starter
AlanSr's Avatar
There not stock tires but stock size for 17's. I can't remember and I'm too lazy to go look right now
245/45/17 I think
42mm offset.
I'm really thinking of dropping it an inch or 2. Maybe going with a 40 series but wider, maybe a 255 or so when I get a new set of tires.
What do you guys think?
AlanSr is offline
post #6 of 10 (permalink) Old 03-30-2012, 01:44 AM Thread Starter
AlanSr's Avatar
These
Eibach Pro-Kit Spring Set
or these
H&R Sport Spring Set
Will I need to upgrade the entire suspension? Or can I just get some new springs?
AlanSr is offline
post #7 of 10 (permalink) Old 03-30-2012, 01:45 AM Thread Starter
AlanSr's Avatar
well I just seen that the link didn't work.
But one set drops about 1 inch in front and .8 in back
The other drops
1.4 in front and 1.3 in back
AlanSr is offline
post #8 of 10 (permalink) Old 03-30-2012, 01:47 AM Thread Starter
AlanSr's Avatar
Wheel dimensions
Offset: 42mm
Backspacing: 5.90"
Bolt Pattern: 5-120
Rec. Tire Size:245/45-17
Weight: 21.4lbs.
AlanSr is offline
post #9 of 10 (permalink) Old 03-30-2012, 10:38 AM
With that big of a drop you'd need shocks specifically for big drops. " (20mm) drop is the limit for standard shocks and IMHO gives a nice stance. Once you go past that the shocks need changing, you run into camber problems and you lose precious travel. There's only about 2"-2" travel at stock height. Taking half that away either gives you a bump stop ride or you need springs that are too stiff for everyday driving. I really like my Lovells 20mm drops. They are stiffer than stock but not too much. Really stiff springs give nice control on a flat race track but make the car hop on street bumps.
post #10 of 10 (permalink) Old 03-30-2012, 10:54 AM Thread Starter
AlanSr's Avatar
ok thank you!
I'm glad I asked before buying them. will 20mm make a difference in appearance?
AlanSr is offline
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
wheels KENWAG79 2004-2006 GTO General Discussion 3 06-05-2006 08:53 PM
new wheels roadracer Wheels and tires 8 02-28-2006 12:04 PM
C5 wheels on GTO jryt Service, Maintenance and Technical Discussion 5 09-16-2005 09:00 PM
