OEM 18" Wheel Q - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-08-2012, 10:59 PM Thread Starter
Giacobazzi's Avatar
OEM 18" Wheel Q
Can someone please tell me the offset and back spacing for the OEM 18" wheel. I can't seem to find this info.
Thanks so much!
Giaco
Giacobazzi is offline
post #2 of 10 (permalink) Old 10-09-2012, 07:35 AM
AlaGreyGoat's Avatar
I think the 18s are the same as the stock 17s??
Stock 8" 17s are listed as +48mm offset, but actually measure +50mm with
a 6.47" backspace.
Larry
AlaGreyGoat is offline
post #3 of 10 (permalink) Old 10-09-2012, 09:05 AM Thread Starter
Giacobazzi's Avatar
Thanks Larry! So if I were to go with a +45mm offset wheel, this 2-5mm less of offset would bring my tire out toward the fender lip, or more inward toward the strut? I'm thinking inward.
Giaco
post #4 of 10 (permalink) Old 10-09-2012, 10:00 AM
Smaller offset is more to the outside with the same width wheel. A few mm wouldn't even be noticeable.
post #5 of 10 (permalink) Old 10-09-2012, 11:10 AM Thread Starter
Giacobazzi's Avatar
Cool! Thank you!
Giaco
post #6 of 10 (permalink) Old 10-10-2012, 07:10 PM
A few mm positive on the front, could make a difference.
On some cars, the stock offset rubs the strut.
On the rear it wouldn't matter.
Larry
post #7 of 10 (permalink) Old 10-11-2012, 06:20 PM
Larry
Even if it did have more positive offset it would be extremely easy to fix with some ARP wheel studs and a thin wheel spacer. When you widen stock wheels like I did with my rear wheels the extra inch made the offset +61mm (half the total of the addition plus the original 48mm). I brought that back to +56mm with ARPs and 5mm spacers. You can go up to about 7mm and still be sufficiently on the hub. Considerably too small of an offset is much more of a problem.
post #8 of 10 (permalink) Old 10-11-2012, 08:25 PM
^^True, but you need hubcentric spacers, if you exceed about
4mm thick, or the wheel bore won't rest on the hub. Plus, this is about the
max to get a full lug nut on the stock studs.
A spacer over about 4mm needs to be hubcentric to the hub and have
a hubcentric fit to the wheel, also.
Also need longer (and stronger) studs, as svede stated.
Larry
post #9 of 10 (permalink) Old 10-11-2012, 08:51 PM
I use a 5mm spacer. There's still plenty of hub. I think it's foolish to not replace the studs regardless. The stock ones are extremely soft and snap easily. Some have snapped them launching the car. I consider it a safety upgrade.
post #10 of 10 (permalink) Old 10-14-2012, 10:40 AM Thread Starter
Giacobazzi's Avatar
The wheels I am looking at are +45mm offset and are 18 x 8 wide. I at least want 245/40/18s on them. I'd may go wider in back, but would also like to be able to rotate them, so I'm not sure which way I will go.
Giaco
Need winter 16"or 17" steel wheel suggestion first65now05 Wheels and tires 5 09-14-2011 10:06 PM
Need an 18" 05 wheel LS2Stampede Wheels and tires 1 07-02-2010 10:28 AM
Major sideways "kick" with burnouts/wheel spin?? 04black6mt 2004-2006 GTO General Discussion 6 08-14-2006 11:06 PM
Flat Tire "Org. Wheel Doesn't Fit in the Trunk" DJ_YellowGTO 2004-2006 GTO General Discussion 4 12-17-2004 04:03 PM
