rear wheel queak - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-24-2011, 10:20 PM Thread Starter
rear wheel queak
I just got an 05 gto about 1 month ago and everything was fine with it. but a few days after I got it the rear wheels started to squeak when I would drive. It wasnt that loud in the beginning but now it is very loud. When I break the noise goes away. When I swerve from one side to the other the noise will get louder. I took it to a shop and they said theres nothing wrong with it. I got new pads thinking it might be that but that didnt fix it and the mechanic said doing the bearings might fix it but hes not sure. Has anyone else had this problem?
irishdude is offline
post #2 of 2 (permalink) Old 06-24-2011, 10:35 PM
Falco21's Avatar
If the sound is speed dependent and not RPM dependent, then it is your wheel bearings. It could be your brakes, but I highly doubt it if the sound stops when applying the brakes. 99% sure its a wheel bearing, whether its the right or left rear.
Falco21 is offline
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
rear wheel squeak irishdude Drive train, suspension, alignment and brakes. 1 06-23-2011 10:42 PM
Rear Wheel Alignment Vettekid1992 Drive train, suspension, alignment and brakes. 1 06-04-2010 09:21 PM
How much rear wheel HP kanibal Engine Discussions 3 01-05-2007 12:23 AM
Rear wheel HP StangStalker Service, Maintenance and Technical Discussion 1 08-27-2005 09:47 PM
