recommendations please - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-23-2017, 10:01 AM Thread Starter
I recently purchased a 1970 Judge. It has the wrong wheels on it and I would like to improve the looks. My big issue with all the cars of this era is that the tire/wheel does NOT fill out the wheel well appropriately. I was thinking of going with a G70-14 and would like a recommendation on wheel width and offset. I am also considering going with a 15" wheel, but what size tire would you suggest, and again, what offset? In either case, they will be rally II wheels to maintain the "original look", and what brand of tire do you recommend (for this same reason)?
truetriplex is online now
post #2 of 2 (permalink) Old 10-23-2017, 07:51 PM
My opinion only --- I'm not a big fan of the huge wheel look, personally. I went with 15" reproduction Rallye II's on my 69 GTO instead of the stock 14's. They aren't noticeably different. As far as tire size and offset, be aware that these cars can vary a lot from one to another because of factory tolerances (or the lack thereof), and also prior collision damage that may have occurred in the car's history. If you want to push the envelope as far as fit, then the only way to be sure is to measure your specific car (all 4 wheel openings), using a tool ---- such as the one called "Percy's Wheelrite" (google it).
Recommendations 1972GTOWW5 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 10-07-2017 01:59 PM
Oil Recommendations 66GTOMN 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 05-28-2013 08:02 AM
Shop recommendations? GymChamp 2004-2006 GTO General Discussion 3 01-12-2010 09:43 PM
Recommendations Gentle Gto 2004-2006 GTO General Discussion 3 05-05-2006 03:22 AM
Need Recommendations... GumbyGoat Service, Maintenance and Technical Discussion 3 04-26-2005 06:35 PM
