Trying to find how to choose tire size - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-16-2012, 07:43 AM Thread Starter
I currently have a 2004 GTO, with a lovell stock height eliminator kit Drag DR-37 wheels, 40mm offset, 18x8" rim
On the front have 245/40/18, rear 265/35/18
Wondering if this is a good setup to have or what is recommended, it is partly a daily driver but planning to make it a project car, have been running Pirelli P-Zero all season tires on it and in need of front tires so wanting to get advice prior to purchase
Jeffcarr is offline
post #2 of 7 (permalink) Old 12-27-2012, 12:13 PM
There are a bunch of different answers that are going to pop up here. It all depends on what your goal is. If it is a daily driver then that is going to drive your selection just as much as if you are looking to stick drag wheels/tires on there. It will depend on how much sag you get either by launching it or by carrying extra passengers or groceries.
Personally, if/when I settle on what wheel tire combo I wanted I would also get a set of drag bags to help keep the rear from squatting too much and rubbing on your new tires
msclhed79 is offline
post #3 of 7 (permalink) Old 12-28-2012, 02:57 PM
jpalamar's Avatar
245s fit nicely on a 8" wheel.
04 GTO - sold
jpalamar is offline
post #4 of 7 (permalink) Old 12-28-2012, 03:34 PM
HP11's Avatar
Quoted: 24 Post(s)
Not so much. It took about a month and a half to get two......maybe because tire and wheel fitment has been discussed so many times here. A search is what would bring up a 'bunch of different answers'......
HP11 is offline
post #5 of 7 (permalink) Old 01-08-2013, 01:56 PM
I use 245s on 8's also, very happy with the setup.
Originally Posted by Jeffcarr View Post
I currently have a 2004 GTO, with a lovell stock height eliminator kit Drag cars DR-37 wheels, 40mm offset, 18x8" rim
Wondering if this is a good setup to have or what is recommended, it is partly a daily driver but planning to make it a project car, have been running Pirelli P-Zero all season cheap tires on it and in need of front tires so wanting to get advice prior to purchase
trev0006 is offline
post #6 of 7 (permalink) Old 01-08-2013, 04:43 PM
psycho1000r's Avatar
i use to run 235 on the front and 255 on my 18x8, no problems at all.
i run 245 on the front and 275 on the rear now with my thruxtons. the rears rub like a bitch unless i inflate my drag bags. im running a 40 series tires on the back though. cant wait to get rid of them and put the proper 35s on.
i usually run Hankook Ventus V12s. great price, they seem to handle well and last decently long.
Kooks Signature Series stepped LTs, Bassani cat back, Magnaflow X-pipe, Svede OTRCAI w/ vector HSRK, P.P TB and Intake, AI ported 226cc 243 heads, Predator cam 230/230 .612 .612 114, SLP UDP, LS7 Clutch, GMM street
psycho1000r is offline
post #7 of 7 (permalink) Old 01-10-2013, 08:25 AM Thread Starter
Appreciate the input, I did go with the pirelli p zero 245-40s on the front, and since I have noticed a problem but don't think it is the tire, if I turn the wheel to the slightest right I get a humming noise and vibration of the front driver side. Straight or going left is fine, needing to test the wheel bearing as it is the current suspect.
Jeffcarr is offline
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
Trying to find the right all season tire Jeffcarr Wheels and tires 4 10-10-2011 10:25 PM
what tire size. The Chosen One Wheels and tires 5 06-07-2011 02:29 PM
need tire size scy-co 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-23-2010 10:31 PM
What wheel and tire sizes i can fit on my 06 and where to find them??? Hanks06gto Wheels and tires 5 03-05-2007 08:47 PM
