Which wheel sticks out more? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-09-2012, 01:00 PM Thread Starter
So I put some 18x9.5 wheels on the back with a offset of 40 on my 04. Well the tires rub even with the fenders cut. So I'm going to try and get wheels that sit further in. I found a set I really like that are 18x 8.5 with an offset of 38. I know that the lower the number the further they Stick out, but is that true with a tire that is an inch less wide?
Ryrob001 is offline
post #2 of 3 (permalink) Old 06-09-2012, 02:59 PM
Strictly in wheel position you will actually gain clearance with the 2mm shorter backspace of 38mm because you're taking away wheel width too. Tire width affects it a little as too wide of a tire can bulge out past the rim but I think you will be OK. That's almost 1/2"
Wheel Offset Calculator
post #3 of 3 (permalink) Old 06-09-2012, 05:05 PM Thread Starter
Thank you so much for that link! It will really help me pick the correct wheels
Ryrob001 is offline
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
One tire sticks out more than the other Alireza Drive train, suspension, alignment and brakes. 3 04-17-2012 06:06 PM
Caddy finally sticks it to BMW... IROCDave The Lounge 2 05-08-2009 09:03 PM
Wheel Hop BLK GOAT Service, Maintenance and Technical Discussion 11 10-15-2005 12:29 PM
Need wheel help roadracer 2004-2006 GTO General Discussion 15 02-02-2005 07:44 PM
