Wheels help - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-04-2015, 08:40 AM Thread Starter
Wheels help
I have jegs wheels. 5x4.75 7in wide. Will they fit?
mattys05 is offline
post #2 of 4 (permalink) Old 03-04-2015, 10:58 AM
DEX
DEX's Avatar
Probably need a little more info to answer this.
DEX is offline
post #3 of 4 (permalink) Old 03-04-2015, 11:01 AM
DEX
DEX's Avatar
Have any pics?
DEX is offline
post #4 of 4 (permalink) Old 03-06-2015, 10:19 AM
Back spacing is the critical number. You need something around 6" BS. The 4.75 lug spacing is also incorrect being off a small 0.65 mm. The stock wheels are hub-centric meaning that the wheel is supported by the hub and the lugs just hold the wheel in place. 4.75" wheels without the correct size centering hub inset in them use just the lugs.
They have been used successfully but care is needed to center the wheel properly and IMHO it is essential that the lug studs which are very soft be replaced with ARP studs as they are all that support the car's weight. That all said I sure wouldn't put narrower wheels on. 9"-9 1/2" (and even larger BS for them) would be a lot more desirable for the effort required.
Lexani Wheels Giveaway - Win a $1500 Set of Wheels! carid CARiD.com 0 04-26-2012 09:21 AM
BMW Wheels - ASA Wheels for 05 M3 on 05 GTO? noel the legend Wheels and tires 9 03-06-2012 07:52 AM
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
new wheels travy082 Exterior Discussions 4 04-02-2009 01:45 PM
