Will 19" wheels work without mods? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 10-13-2011, 07:23 PM Thread Starter
Hello,
I'm looking into purchasing a set of staggered aftermarket wheels for me 04 GTO. I've read that 18's are the best way to go, but I've found a really nice set of 19's and would appreciate any information or members experience.
The wheels are 19x8.5 (35mm) front and 19x10 (38mm) rear. I'm thinking on a tire combination of 245-40-19 and 265-35-19. Do you think this combo will work without rolling my fenders or anyother mods?
Thanks for your time.
tleroy is offline
post #2 of 16 (permalink) Old 10-13-2011, 09:11 PM
87GN06GTO07IRL's Avatar
You'll need to flatten the fender lips in the rear and might need to even have them flared. I use a 18x9.5 35mm on 265/35's and had to roll the fenders. You'll be out further than that. A 30 series tire will also be a better fit.
87GN06GTO07IRL is offline
post #3 of 16 (permalink) Old 10-14-2011, 08:24 AM Thread Starter
Thanks for the advice. I really didn't want to roll my fenders, so guess I'll continue to look for other wheels with favorable backspace.
tleroy is offline
post #4 of 16 (permalink) Old 10-14-2011, 07:39 PM
ducky1978's Avatar
i have 19x10 with a 275/30. they fit but if rear was out of alignment any they would rub.
faster and faster till the thrill of speed over comes the fear of death
ducky1978 is offline
post #5 of 16 (permalink) Old 10-15-2011, 02:46 PM Thread Starter
Looks Good! What is the backspacing of your wheels? Did you roll your fenders?
Thanks,
tleroy is offline
post #6 of 16 (permalink) Old 10-17-2011, 02:39 PM
jpalamar's Avatar
Originally Posted by tleroy View Post
Hello,
No point buying a 10" wide rear wheel if your only going to run a 265 tire. It will be like the ricer VWs with streched tires and extra weight for no reason.
I've road in cars that had stock 17s, 18s, and aftermarket 19s all on stock suspension. I thought the 19s sucked because of how hard a ride they had from no sidewall. They occasionly rubbed but I don't know the offsets. I do know it was a 8" wide wheels with a 235 tire though.
04 GTO - sold
jpalamar is offline
post #7 of 16 (permalink) Old 10-17-2011, 04:51 PM
A 265 on a 10" will have less sidewall flex and squirm than a 265 on a 9". The wider the wheel the better. A 265 on a 10" will handle way better than a 275 crammed on a 8". A 265 on a 10" will not stretch, it will be flush. I use a 265 on a 9.5" and it has slight bulge. If you buy light weight wheels it won't matter. My 265's on 9.5" weigh 6lbs. less than the stock 18's with 235's and they actually grip on the curves. Just gotta do your homework.
post #8 of 16 (permalink) Old 10-18-2011, 07:07 AM
jpalamar's Avatar
I just think a 10" wide wheel should be used for a wider tire like 285+.
04 GTO - sold
jpalamar is offline
post #9 of 16 (permalink) Old 10-31-2011, 03:36 PM Thread Starter
Thanks for the comments guys. I think 9 or 9.5 will be as wide as I'm going. It's been hard to find a good looking wheel with the correct offset at a reasonable price. I'm getting tired of looking.
Found Beyern 5's but the offset is 30mm that has been milled to 35mm on a 9.5" wheel. Do know if this will work or not?
tleroy is offline
post #10 of 16 (permalink) Old 10-31-2011, 07:49 PM
That's the size i use on all four. Slight roll of the fenders is all you'll need.
+13 offset wheels work?? GTOFEVR Wheels and tires 4 04-15-2010 08:05 AM
What are essential "must do" mods? GymChamp 2004-2006 GTO General Discussion 21 02-02-2010 10:04 PM
New Wheels/Appearance Mods Q-Man Exterior Discussions 9 07-15-2008 12:23 PM
NEW WHEELS and Mods! What do you think? u-got-gto 2004-2006 GTO General Discussion 13 05-30-2007 12:21 PM
Will Stock 2000 z-28 wheels work on the rear of my 06 GTO? yamaouch08 Wheels and tires 0 07-22-2006 05:10 PM
