Will 275/40/18 on 18x9.5 rims work? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-06-2011, 10:15 PM Thread Starter
BL3
Will those size tires work on a 2004 gto without fender rolling? Not sure that size tire would work for the front, but what tire could i put on the front to make the 9.5 rim fit? Need to know asap! Thanks
BL3 is offline
post #2 of 5 (permalink) Old 11-06-2011, 10:32 PM
87GN06GTO07IRL's Avatar
Depends on the offset. You'll probably need a fender roll though. I use 265/35/18 on all four with a 18x9.5 35mm offset. Slight fender roll was all i needed. You'll need offset strut mounts to make a 275 work on the front. I have three brand new sets, pm me if interested in one.
87GN06GTO07IRL is offline
post #3 of 5 (permalink) Old 11-06-2011, 10:58 PM Thread Starter
BL3
Can I put a smaller tire on the 9.5 rim? The wheels im looking at are c6 vette wheels. Not sure of there offset? And i cant get anybody to explain this fender roll thing?
BL3 is offline
post #4 of 5 (permalink) Old 11-07-2011, 10:44 AM
Their offset? Look on the inside. It should be stamped somewhere. If you can't find it measure the distance from the back mounting face to where a straight edge is laid across the back rim.
post #5 of 5 (permalink) Old 11-12-2011, 07:57 PM
The "correct" size would be 275/35/18 for the rear if you go with a 235/40 or 245/40 up front
Ol' Yeller is offline
18x9 with 35mm offset dollabillz13 Wheels and tires 10 03-10-2011 11:41 PM
Will these rims work? kspecial41 Wheels and tires 2 10-28-2010 08:06 PM
18x9 275/35r18 Offset? QuikslvrGoat Wheels and tires 13 04-13-2010 11:43 AM
