Will my tires rub due to a larger aspect ratio? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-12-2015, 09:20 AM Thread Starter
I'm looking at a 9.5" wide rear wheel and I can't decide on which size wheel to get.
LastZephyr23 is offline
post #2 of 7 (permalink) Old 08-12-2015, 11:19 AM
AlaGreyGoat's Avatar
The offset of the wheel and the size of the tire will
determine if it will rub.
Larry
AlaGreyGoat is offline
post #3 of 7 (permalink) Old 10-09-2015, 12:21 PM Thread Starter
Could you explain?
post #4 of 7 (permalink) Old 10-09-2015, 07:37 PM
With the stock 8" wide x +48mm offset (6 3/8" Back Space) rims, you can't run any wider tires than the 245s on the front. 255s will rub the struts.
On the rear, you should be able to run 275s.
I run 245/45/17 front and 275/40/17 rear on stock rims and have
rolled the rear fender well.
Also, the bolt pattern is 5 on 120mm (odd) and a 69.5 hub bore
(also, odd).
Larry
post #5 of 7 (permalink) Old 10-12-2015, 08:19 AM
9.5" takes a big offset somewhere around 50-60mm and inner and outer fender massage. That is close to the limit of how big you can get in there. Inner and outer control arm and subframe bushings also help as that will hold the wheel in place better than the compliant stock ones. Although you can get 275s on a 8" wheel (I've done it too) the contact patch and handling will be improved with a wider rim. I run 9" rims in the back with a 55mm offset and have run 285 tires with no rub and no cheating of jacking up the back end.
post #6 of 7 (permalink) Old 10-21-2015, 08:26 AM Thread Starter
Thanks Guys!
post #7 of 7 (permalink) Old 10-21-2015, 06:24 PM
(also, odd).
Larry
I run 255/17/40 Nitto NT05s on my stock front wheels with ARP studs and 5mm spacers. I run a -1* camber too
Rear tires rub - 67 Tempest chiropaul 1964-1974 Tempest, Lemans & GTO Wheels & Tires 9 05-23-2013 12:16 PM
05 a4 gto tires make noise when on the road possible due to cupping/bad shocks?...... pctek Drive train, suspension, alignment and brakes. 5 08-16-2010 05:50 PM
Tires Rub on Launches SpdKilz Drive train, suspension, alignment and brakes. 24 04-19-2010 12:02 AM
yokohama tires rub???? aarons1k 2004-2006 GTO General Discussion 2 11-23-2009 07:16 PM
Tires rub on deceleration? Poolshark1321 Wheels and tires 4 07-22-2009 11:04 AM
