year one cast aluminum wheels - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-19-2014, 10:43 AM Thread Starter
Quoted: 6 Post(s)
have a 68 gto that I put on the year one 17 inch cast wheels. I replaced 14 inch rally ii's. I'm running 245 45 17's on the new wheels. I know the aluminum wheels have more weight, but I have experienced a significant performance loss with the new wheels compared to the rallys. Does the unsprung weight difference really affect performance that much? Someone mentioned the difference in circumferencemay be affectiing the axle ratio, does that follow? I have a 3:55 posi out back. I love the looks and the ride is fine, but in terms of wheelspinning and fun, the car now seems like a dud. Granted the 17's put more rubber on the road, and the old radial TA's were old and probably hardened with age, but i'm not happy with the performance. Anyone else have those wheels and can give me some feedback?
rlitcher is offline
post #2 of 3 (permalink) Old 10-19-2014, 11:02 AM
Your tires are ~80 2/3 inches, stock was a G78-14 which is ~85 inches. So yes, you have essentially have a 0.95 overdrive on your car.
As for rotating weight, well opinions on that are all over the place. Take your pick. Any poor handling you experience probably is coming from your modern, square profile tires or worn out suspension components.
ibarbuckle is offline
post #3 of 3 (permalink) Old 10-19-2014, 11:09 AM
Also, changing the size of you wheels doesn't affect tractive force. Your contact patch for a shorter, wider tire is probably smaller than stock. Tire height, if carcass/wheel flex can be controlled, is preferable to width.
YEAR ONE rally 2 wheels for 67 gto teamwoody72 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 08-20-2014 08:41 AM
Big Brake Year One 17x9 Wheels jtwoods4 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 08-18-2013 10:14 PM
Year One Rally II Wheels MrAllthat 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 12-10-2011 11:57 AM
Wheels - Chrome or Aluminum? BlackSheep 2004-2006 GTO General Discussion 3 01-13-2007 04:02 PM
