z06 wheels - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-07-2012, 08:44 PM Thread Starter
z06 wheels
Thinking of getting some argent c5 z06 wheels, what modifications would I have to make in order for the wheels to fit?
Dishphead is offline
post #2 of 4 (permalink) Old 03-07-2012, 09:00 PM
AlaGreyGoat's Avatar
First, the bolt pattern is 5 x 4.75 not 5 x 120mm. Also, you will need wheel
spacers/adapters on front and back because the corvette wheels have way to much offset. The hub bore is a little larger, so you will need some very thin hub rings(69.5 mm to 71.4mm - I think?).
Larry
AlaGreyGoat is offline
post #3 of 4 (permalink) Old 03-08-2012, 11:15 AM Thread Starter
thanks larry, i have some eagle gsd3's on my corners right now, but in the front i'm getting just a slight rub against the front of the plastic in the wheel well, am I going to have to sawzall anything out to accommodate the wider tire? I'm also getting strut rub, so I'll probably get some new bushings and bearings but would that solve the problem of the plastic rub? I'd just as soon not have to cut anything out of my car.
post #4 of 4 (permalink) Old 03-08-2012, 09:07 PM
jetstang's Avatar
Buy a C5 to put on top of it, nice upgrade! Jk..
Burning rubber since 1982!!
jetstang is offline
guy says 275 to the wheels? youngGoat 2004-2006 GTO General Discussion 8 07-13-2011 11:29 PM
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
New Aza Z-8 Wheels baaadgoat Wheels and tires 0 02-18-2008 07:02 AM
C5 wheels on GTO jryt Service, Maintenance and Technical Discussion 5 09-16-2005 09:00 PM
