1970 Lock Pull Part Number? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-06-2019, 10:25 PM Thread Starter
Herding Goats's Avatar
Quoted: 5 Post(s)
Hi all,
I am looking for the correct lock pull for a 1970 GTO. A purchased a reproduction from a well-known source and the profile is different. I'd appreciate it if anyone has the original GM part number for the knob or a recommendation for a better reproduction piece. Attached is an image showing the original on left and reproduction on the right. I'd prefer a worn original to something that just isn't the right shape.
Thanks in advance for any insight!
Herding Goats is offline
post #2 of 4 (permalink) Old 01-18-2019, 10:52 AM Thread Starter
Quoted: 5 Post(s)
Thought I’d update this thread with the results of my research in case it helps anyone else out. I found a decent looking replacement from Frank’s Pontiac Parts. Purchased it off their eBay listing. They list Inline Tube’s part number as an alternate part number and photos look similar, so it may be Inline’s piece. I’m just speculating but expect that would be a good alternative. The head shape of the parts received is very close to original, the fluting a little broader, but overall much closer than the other part I had bought.
If anyone has an original part number for the pulls I’d still be interested in that.
These reproduction pulls will work well for me in the interim.
Image shows (left to right) original part, first order (not going to bad mouth supplier but it’s one you know), and latest order which was from Frank’s.
post #3 of 4 (permalink) Old 01-19-2019, 03:08 PM
integrity6987's Avatar
Quoted: 44 Post(s)
Info from scanned Chassis and Body parts Catalog models thru 1963-1975 (rev 11-79) pg 10-51
Description 10.559 Knob, Door inside Lock Rod
Year 61-75 is P/N 9813799 AR .79 Knob (chrome)
Hope this helps you locate what you need. If you score - please PM me.
DK
integrity6987 is offline
post #4 of 4 (permalink) Old 01-20-2019, 11:01 PM Thread Starter
Quoted: 5 Post(s)
Thanks, Integrity. From what I've read the '68-'70 is a different design than other years. For example, '71+ GTO's knobs did not have the fluting which appears to be the style of P/N 9813799. This makes sense given the later publication date and gives me a starting point. I'll be sure to let you know if I track anything down and appreciate the input!
1970 37 Amp Alternator Part Number Red1970GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 03-14-2014 08:27 PM
Pull a part = goodies! OrbitOrange 1964-1974 Tempest, Lemans & GTO General Discussion 5 08-02-2010 06:54 AM
Oil Filter Part Number DrFix2Fly Service, Maintenance and Technical Discussion 7 10-06-2005 04:09 PM
GM Part Number... GTOOOOOH 2004-2006 GTO General Discussion 20 06-10-2005 07:31 PM
Part number for oem mats? DaddySS 2004-2006 GTO General Discussion 8 01-10-2005 07:03 PM
