2006 Console wiring diagram - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-06-2013, 05:56 PM Thread Starter
GTOKIDRH's Avatar
I am putting a '06 interior in my '67. I am modifying the console to fit. Does anyone have a schematic? All I need is to power the compartment light and the 12 volt socket. I do not need to power windows or locks. Not sure which pigtail is the main connector. I am guessing that the yellow is the 12v+ and the black/white is the ground? HELP!
GTOKIDRH is offline
post #2 of 3 (permalink) Old 09-07-2013, 03:16 PM
jmt455's Avatar
Yes, you are correct.
Yellow = +12V
Blk/white stripe = Ground
Brown/white stripe = IP lamp power (dimmer controlled)
Use the yellow for full 12V supply to the compartment lamp and the power outlet.
Use the brown/white for dimmer control of the shift indicator light, if you are using one.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 3 (permalink) Old 09-09-2013, 04:35 PM Thread Starter
GTOKIDRH's Avatar
Thank you!
Thanks so much JMT455! I appreciate the help.
GTOKIDRH is offline
68 GTO Wiring Diagram iCdeez 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-01-2018 08:19 AM
Wiring Diagram LoneStarGoat68 Interior Discussions 1 04-05-2012 08:58 PM
64 GTO wiring diagram askheman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-24-2012 03:18 PM
Wiring diagram gggto Interior Discussions 0 11-13-2011 07:13 PM
70 AC wiring diagram 66TRI 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-06-2011 11:17 AM
