65 GTO Fuel and temp gauges - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-04-2014, 06:27 AM Thread Starter
Hi guys recently picked up a tidy 65 and having some problems with the gauges. The temp and fuel gauges have been replaced with standard looking but obviously aftermarket gauges. The temp gauge reads just nearly 1/4 even when disconected and sat on the bench, thought I might be able to bend the needle a touch but its in a sealed unit and the needle is made of plastic so is too flexible. Obviously I need to get a new gauge but who do you recommend, the gauge fitted has absolutely no numbers or markings on it what so ever. Also has anyone got a diagram for the fuel gauge wiring please as although mine looks new it is not connected and however I seem to connect the wires up it doesn't seem to work correctly.
KoppaK is offline
post #2 of 2 (permalink) Old 02-04-2014, 12:18 PM
It would help to see the gauges but personally I would seek out the factory gauges to replace your questionable aftermarket replacements.
On the fuel gauge it is possible that the sender could be bad or a different amperage than the replacement which would make it read incorrectly. I would also consider replacing the temp sender when you replace the gauge.
Gto having temp gauge problems Mike9529 2004-2006 GTO General Discussion 3 11-12-2013 12:14 PM
66 Rally Gauges from Parts Place; oil/temp dakuhns 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 07-13-2012 11:30 AM
Do I need an Intake Air Temp module for PLX gauges? batmans Interior Discussions 7 06-21-2011 11:31 AM
water temp - 66 gto Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-24-2011 07:13 AM
A/4 Gto Trans Temp LOWET Service, Maintenance and Technical Discussion 5 12-19-2008 02:43 PM
