67 Instrument cluster - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-10-2014, 08:01 PM Thread Starter
I'm trying to re install my 67 gto instrument cluster. Having a bad time with the "tube" that allows the high beam light to get to the front of the panel.
It doesn't seem to allow the cluster to be positioned. If you've done this , you'll know what I'm talking about .. Can anyone help?
rexjet is offline
post #2 of 3 (permalink) Old 12-22-2014, 09:38 AM
I have done it, but has been a while. As I recall, the face is open at the bottom of the cluster housing by about 3/8" when properly assembled. Is this the issue you are looking at? Matt
Matthew is offline
post #3 of 3 (permalink) Old 12-23-2014, 04:54 PM
Quoted: 106 Post(s)
The tube sits oblong end against the back of the gauge face at about 10 o'clock and the round end goes in the ring against the red insert.
Remove the cigarette lighter and swing the grounding plate down so you can set the gauge cluster straight in while holding the clear lens in place by the ends.
The two screws at the end don't tighten all the way down to the post, just tighten them enough so that the instrument rings are holding the clear lens snug.
I just put mine back together, I had to take it out to clean and polish the lens and remove the loose bulbs that had fallen in them over the years.
Novus 2 to polish the lens then finish with Plexus.
I replaced the 6 GI lights with superbright cool white LEDs and also used 2 of them in the heater control.
The gauges really light up now, you might want to consider changing out the incandescents while you have it apart.
Don't use them in the the flashers or anything else just the GI and your gauges will be a lot brighter.
Goat Roper is offline
66 instrument cluster stevebrochu 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-09-2012 02:46 AM
Instrument cluster removal on 67 billcocarb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 11-15-2011 10:33 PM
Restoration of my Instrument Cluster?? Mr66GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 05-28-2011 08:32 PM
64 Instrument Cluster GTOKID64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-13-2010 07:27 PM
Access instrument cluster sknight751 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-25-2009 10:13 AM
