Cruise control issue - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-23-2012, 05:05 PM Thread Starter
Hi I am a new member. I have a 2005 GTO with a litlle over 30k on it. I am having a problem with the cruise control disabling itself. sometimes it works fine with no issues. other times it works for a while then shuts its self off and says cruise disabled and wont turn on again. This last time it wouldn't turn on at all. I'm thinking its the switch but I dont want to condemn it before I know. Has anyone on here had any problems with there cruise control. Any help would be greatly appreciated
Goat Head is offline
post #2 of 4 (permalink) Old 07-17-2012, 09:19 PM
derektodd229's Avatar
my cruise control doesn't work at all. and I know this is going to sound weird, but my keyless entry only works at night..
derektodd229 is offline
post #3 of 4 (permalink) Old 07-17-2012, 10:35 PM
AlaGreyGoat's Avatar
Scan it for codes. I think a bad wheel sensor will cause the problem.
Larry
AlaGreyGoat is offline
post #4 of 4 (permalink) Old 07-20-2012, 01:32 PM
jpalamar's Avatar
OP... are you by chance using the brakes or shifting when the cruise control turns off?
Ala is right, a bay sensor can cause things like cruise/traction/ABS to disable.
Def scan for codes.
04 GTO - sold
jpalamar is offline
Cruise control issue 04GTO1605 2004-2006 GTO General Discussion 0 03-31-2012 01:09 PM
Cruise Control Barricade 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 08-21-2011 03:25 PM
1967 Cruise Control milster1091 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-29-2011 10:22 PM
Cruise control and ICP johnjones36 Interior Discussions 2 04-02-2009 07:45 PM
Cruise control question. Aramz06 Service, Maintenance and Technical Discussion 3 01-13-2009 08:14 AM
