drivers window only goes quater way down! - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-24-2008, 09:06 PM Thread Starter
Hello,
Just wondering if anyone has had a problem with drivers window only going 1/4 of way and make crunching sound ! Have not removed door panel yet also seems to pop door open when you put it down HUM ?
2fas4u428 is offline
post #2 of 6 (permalink) Old 10-30-2008, 05:24 PM
alsgto04's Avatar
So did you get it fixed cause im also having the same problem but on my 92 Regal it also makes that same crunching sound.
alsgto04 is offline
post #3 of 6 (permalink) Old 12-24-2008, 01:36 PM
Well, I've heard stories of guys pulling door panels off car doors from brand new vehicles with similar symptoms.... They sometimes find empty pop cans inside..
Apparently they either can't find the garbage can while on the line, or just needed some amusement. :P
LS2Monaro is offline
post #4 of 6 (permalink) Old 12-24-2008, 04:10 PM
Aramz06's Avatar
Send a message via AIM to Aramz06
Did you check if the Rubber seal is hooking under the window and causing friction? That has happen to me before and I simply pulled it out with a credit card.
-LSS Shifter
-Resonator Delete
-Flowmaster 44 Series Mufflers
1 of 475
Aramz06 is offline
post #5 of 6 (permalink) Old 02-16-2009, 08:44 PM
06goatm6's Avatar
Im not fully familiar with the inside of the GTO doors but I have worked on quite a few other GMs Buicks etc....If the GTO has cable operated window regulators this sounds like your problem. From the crunching noise your describing it sounds a lot like those other GMs. They have a power window motor which runs a set of cables, almost like bicycle brake cables, and they tend to bind up and come out of place inside the door. Chances are you will need a new window regulator.
06 GTO IBM 408 Stroker-Sold
06 Corvette, Supercharged 607whp, RPM trans and Diff, RPS twin disc, Z06 susp, Dewitts Rad, Custom Fuel system
06goatm6 is offline
post #6 of 6 (permalink) Old 02-19-2009, 09:01 AM
the same thing happend on mine the front track came off the window so i glued it back on with 3m black window urethane work good so far been 3 months .
dub29 is offline
passenger window screwed up dustyminpin 2004-2006 GTO General Discussion 6 06-09-2010 04:43 PM
Looking for a New GTO in the area PSU GTO 2004-2006 GTO General Discussion 22 06-27-2007 09:18 AM
Drivers side window GTO_Mike Interior Discussions 3 08-09-2006 02:57 PM
Pontiac Pro Stock Showdown Will Feature NHRA's Finest Drivers 05GTO In the News 0 01-11-2006 06:02 PM
General Motors Captures 16 Racing Championships in 2005 05GTO In the News 1 12-01-2005 05:24 AM
