fuse for radio? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-26-2009, 11:43 AM Thread Starter
fuse for radio?
my buddy has a 200x gto. he had some work done on his car and says the stock bose radio hasnt worked since, i am guessing either a fuse or a wire isnt attached. can anyone give me a link to see a wiring diagram? if the brand radio he claims he has is wrong its no biggie. i am just looking for ideas cause he hasnt been able to fix it for 2 years and a case of beer says i can fix it in under 24 hours after we get back from iraq in june.
thanks for the help.
oh, if you would rather email instead of posting here my email is [email protected]
thehick15 is offline
post #2 of 4 (permalink) Old 03-26-2009, 06:43 PM
GM4life's Avatar
Does it turn on? The fuse for the radio is under the dash.
GM4life is offline
post #3 of 4 (permalink) Old 03-28-2009, 11:53 AM Thread Starter
they tell me it wont do anything. no on, off. nothing. I am guessing that they checked the standard fuse box and nothing else. If it isnt that then its a disconnected wire and thats no problem either. thank you for the diagram. It is very informative.
post #4 of 4 (permalink) Old 03-28-2009, 06:48 PM
GM4life's Avatar
Anytime, the radio is probly shot. Pull out the radio and with a multimeter check A7 and A2 on the connector for 12 volts. Also check to make sure it has good ground.
GM4life is offline
Ok, where the hell is the Fuse box? RevnR6 Interior Discussions 9 05-24-2011 12:26 AM
Turn light fuse blows sometimes CrazyGerman Service, Maintenance and Technical Discussion 4 08-26-2008 01:20 PM
Oh-oh, took the car in for a blown fuse!!!! anmracing 2004-2006 GTO General Discussion 8 06-05-2007 11:21 AM
Turn Signal Fuse keeps blowing after radar detector install HotRodGuy Service, Maintenance and Technical Discussion 13 02-28-2006 10:30 PM
Interior Fuse Block Access hawk14414 Service, Maintenance and Technical Discussion 3 10-25-2004 08:23 PM
