Gauge backlights - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-10-2013, 03:42 PM Thread Starter
Gauge backlights
I have 2 VDO full sweep electrical gauges. I don't really need help with the install of the gauges themselves, but I'm not sure where to tie into the headlight switch to trigger the backlights. My goat doesn't have the smoker's package I've heard about. Are the wires still there? (where exactly)
Thank you for any + all help.
Metallifan is offline
post #2 of 3 (permalink) Old 02-10-2013, 09:12 PM
68OldGoat's Avatar
If you have an 04 or 05 then NO there is no wiring to tie into. If you have an 06, then there should be a plug just behind the "Smokers Package" opening....on the passengers side. You should be able to access it by removing the center console side panel.
68OldGoat is offline
post #3 of 3 (permalink) Old 02-10-2013, 09:52 PM Thread Starter
I have an 04. There's nowhere? What about the headlight switch to the left of the steering wheel?
3 or 4 gauge A-pillar gauge pod 06BlazinGTO 2004-2006 GTO General Discussion 2 07-31-2011 08:57 PM
Gauge trim panelwith round gauge in corners, cpr Interior Discussions 1 05-19-2011 04:14 PM
oil psi gauge The intimidator Service, Maintenance and Technical Discussion 1 03-20-2010 09:07 PM
fuel pressure gauge & boost gauge sdgoat Service, Maintenance and Technical Discussion 4 05-12-2006 09:34 AM
