GTO Key Ressurection -- HELP needed! - Pontiac GTO Forum
post #1 of 11 (permalink) Old 09-24-2012, 10:57 AM Thread Starter
BobS's Avatar
I laundered my key. Oh no!
And I spelled resurrection wrong. Double oh-no!
It still will start the car, but the buttons no longer remotely unlock the car or trunk.
I couldn't figure out how to non-destructively open the key -- presuming the battery may not have survived the wash cycle.
Other ideas for how I might save this key?
Thanks!
Bob
BobS is offline
post #2 of 11 (permalink) Old 09-24-2012, 11:04 AM
HP11's Avatar
Quoted: 24 Post(s)
There are threads on opening them up to change the battery but, based on what I've seen, buy a new fob.....it's much less hassle.
HP11 is online now
post #3 of 11 (permalink) Old 09-24-2012, 11:18 AM Thread Starter
BobS's Avatar
Thanks - I found the threads about reprogramming....
I've tried unscrewing the metal key portion, and prying inside that slot (to open the fob case) but I am concerned I'm going to break the plastic case.
Some of the threads say 'sealed for life'. What did anyone out there have to do in order to open it up?
Thanks,
Bob
BobS is offline
post #4 of 11 (permalink) Old 09-24-2012, 12:25 PM
jpalamar's Avatar
I believe the fob is glued but can be pulled apart though.
Its a standard button cell that has solder tabs on it.
04 GTO - sold
jpalamar is offline
post #5 of 11 (permalink) Old 09-24-2012, 01:26 PM
Through the key into a bag of rice, it'll suck the moisture out of it.Worked when I washed my phone my mistake.
post #6 of 11 (permalink) Old 09-24-2012, 03:13 PM
ViperT4's Avatar
I'm doing the same thing right now. Spending a little time in the basement is much better than spending ~$100 on one new key fob.
Key Fob Battery Replacement...w/pics - LS1GTO.com Forums
2004 GTO M6 Torrid Red
Ai ported 243s-ported Fast 90-FTI Tigershark cam-Kooks headers & cats ???hp/???tq
ViperT4 is offline
post #7 of 11 (permalink) Old 09-24-2012, 03:48 PM
HP11's Avatar
Quoted: 24 Post(s)
Life is too short....the transmitter was only 36 bucks when I bought mine.
HP11 is online now
post #8 of 11 (permalink) Old 09-24-2012, 06:28 PM
SpicyRed06's Avatar
I have read threads on here about replacing the battery etc.. and it sounds like a hassle. My dealer wanted over $300 for a new one. The battery in mine is dying rapidly and to avoid the whole thing I just got an aftermarket (Python) alarm with its own fob. It was about $250 with install and I never have to use the GTO key fob. Makes for a full pocket with the key and another fob, but you have the added security as well.
Note: According to my shop guy, install was a huuuge bitch. Needed all sorts of extra relays etc. However he didn't charge me more. Remote start is near impossible on our cars so I didn't go there.
2006 A4 SRM - K&N intake - Pedders Springs, shocks, struts - Hotchkis front/rear swaybars - JBA shortys, catted mids, SLP LM2 - Driveshaft Works 1 Piece aluminum
Chicago IL
SpicyRed06 is offline
post #9 of 11 (permalink) Old 10-30-2012, 06:45 PM
Where'd you find a transmitter for that price?
6shooter is offline
post #10 of 11 (permalink) Old 01-02-2013, 02:13 AM
Buddy whatever way u look at it ur in a tough spot, i lost my key the other day but i remembered a website, ikeyless.com, i bought a new key from them, and had a locksmith attempt to program it, he will have to reprogram ur ignition codes to work with the key because no one really caries those codes and for some reason gtos dont pare up with new keys... whatever u do DO NOT GET A USED KEY FOR THIS PROCESS, those keys once programmed will only work on one gto forever u cant reprogram them. The key with the battery will cost u 100$ having a teck program it for u will cost anywhere from 50 to 100 dollars, and the worst part of all... u have to hope someone is willing to go thru the trouble, those tecknitians, once they see what they r up against usually dont want to go thru the hastle
Sent from my LG-MS770 using AutoGuide.Com Free App
PabloGTO is offline
serious help needed! nrizzo04 2004-2006 GTO General Discussion 9 04-16-2012 08:29 PM
!Help needed! 05GTO05 Service, Maintenance and Technical Discussion 3 03-21-2007 10:40 PM
