Guages for F/I - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-31-2011, 12:12 AM Thread Starter
Guages for F/I
Installing Edelbrock E Force supercharger this spring and want to add 2 gauges to center stack, like SCSS product, what gauges, AFR, boost, oil pressure or Aeroforce scan guage? What info is most important with F/I? Thanks
SWGOAT is offline
post #2 of 4 (permalink) Old 02-05-2012, 08:42 PM
I would put a wide band in there... You want to know when you run lean and when you run rich.
Sent from my PC36100 using Tapatalk
JoeandReeseGTO is offline
post #3 of 4 (permalink) Old 02-05-2012, 10:25 PM
87GN06GTO07IRL's Avatar
Wide band and Interceptor are what i use. The interceptor monitors boost so no need for a separate gauge.
87GN06GTO07IRL is offline
post #4 of 4 (permalink) Old 04-17-2012, 01:46 PM
Im going to run a wide band and fuel pressure and boost. This way you can diagnose quick and in a hurry. Depends how much boost your running.. i would say fuel pressure is very important. If your fuel pump starts to crap out and you go lean. you can burn your engine up. But a wideband will show that your air to fuel ratio is off also. I like to know exactly what my engine is doing lol
Firehawk68McLeod is offline
guages crazyflames3 740tank 2004-2006 GTO General Discussion 10 03-02-2010 10:24 AM
Swapping guages jpalamar Service, Maintenance and Technical Discussion 18 02-14-2010 09:23 PM
Guages for 04 GTO GTOBert 2004-2006 GTO General Discussion 4 01-28-2005 06:29 PM
guages roadracer 2004-2006 GTO General Discussion 1 11-14-2004 02:29 PM
