heat not working. valve not opening - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-10-2014, 03:50 PM Thread Starter
My 69 GTO with A/C will not put out heat or switch control levels to defrost, bi level, etc. When I pull vacuum hose of heater valve, I can blow through it like there is a leak. Is this normal? I am getting 20" of vacuum at cruising speeds, I measured it with a gauge so there is enough vacuum. A/C compressor comes on and works, I just can't switch levels to direct the air.
Also my brakes work horribly ever since I changed my master cylinder and proportioning valve. Pedal is very hard and tires will not lock up with extreme leg pressure. I took off master cylinder and checked pedal, was fine. When I pulled out power piston on booster, I heard vacuum pressure relieve.
69gr81 is offline
Intake valve not opening!!! OrbitOrange 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 08-15-2013 10:39 PM
dash gage opening color 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 03-25-2011 02:40 PM
Wheel opening moldings? ShadoWolf Exterior Discussions 5 04-16-2010 09:45 AM
?opening up hood scoops? clarkaim 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-10-2009 10:18 AM
Trunk not opening inteltom 2004-2006 GTO General Discussion 16 04-10-2007 11:14 AM
