Holden center console gauges - Pontiac GTO Forum
post #1 of 16 (permalink) Old 06-01-2014, 08:52 AM Thread Starter
kirk44's Avatar
I have a 2006 with a build date of September 05. Does this car have the gauge harness already under the cover and if so is it hard to get at if I only remove the top cover. I would like to disturb as little as possi . Thanks Kenny
kirk44 is offline
post #2 of 16 (permalink) Old 06-01-2014, 01:12 PM
700Rocket's Avatar
Should have the harness but you need to take off more than the top cover to find it. Car built after Feb of 2006 don't have the harness.
700Rocket is offline
post #3 of 16 (permalink) Old 06-02-2014, 06:33 AM Thread Starter
kirk44's Avatar
Okay thanks I was hoping I could get lucky and it was under the top cover. Is it behind the A/C vents?
kirk44 is offline
post #4 of 16 (permalink) Old 06-02-2014, 08:05 AM
HP11's Avatar
Quoted: 24 Post(s)
IIRC, you'll have the remove the enter waterfall to find the harness, similar to what you have to do to change the radio.
HP11 is offline
post #5 of 16 (permalink) Old 06-02-2014, 09:47 AM Thread Starter
kirk44's Avatar
Okay thanks for the info I really like the way those gauges look. Don't know why a performance car like this didn't come from the factory with full instrumentation.
kirk44 is offline
post #6 of 16 (permalink) Old 06-02-2014, 10:31 AM
When you remove the cover plate you will see a foam brace in the back portion of the opening. This secures the right and left side of the dash. JHP directions say to cut it DO NOT CUT IT. Why? It helps stabilizes both right and left sides. There is no reason to cut it, the wires can be fished around it.
Also the directions say to remove the front trim around the radio and vents. This is for easy access to the harness that lays right behind the vents. What I an others did was get a metal coat hanger and make a hook. Fish that hook down just behind the vents you will feel wires. If you have a mirror it will help you look down into that cavity. I did it blindly. I snared the wires and pulled up and up came the harness. Took all but 30 seconds. For 2005 it was plug and play.
You may want to try that before removing the trim.
post #7 of 16 (permalink) Old 06-02-2014, 12:56 PM Thread Starter
kirk44's Avatar
Thanks I will try that first
kirk44 is offline
post #8 of 16 (permalink) Old 06-03-2014, 05:49 AM Thread Starter
kirk44's Avatar
I came across this part number 92163811. Does anyone know of it is the right one for my car. The seller is not sure.
kirk44 is offline
post #9 of 16 (permalink) Old 06-03-2014, 06:25 AM
silversport's Avatar
you have to find the ones made for the American car as the Australian/UK version will be angled the wrong way for us...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #10 of 16 (permalink) Old 06-03-2014, 01:14 PM Thread Starter
kirk44's Avatar
Thanks I knew it was too good to be true. I found one for sale on eBay for 400 but its in Australia. There were a lot of pics but it was hard to tell.
kirk44 is offline
66 Center Console xconcepts 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 05-30-2017 08:43 AM
Center console '66 Miami Ragtop 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 06-13-2011 08:17 AM
