Ignition stays in acc - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-10-2015, 01:00 PM Thread Starter
04 gto just started doing this when i take the key out the radio ,aux plug in glove box, and windshield wipers all continue to work. All fuses and relays are good any idea how to fix this issue thanks.
firehealer is offline
post #2 of 3 (permalink) Old 02-12-2015, 03:39 PM
i have the a similar problem. before you pull the key all the way out, i just give it a little jiggle, it should click and lock the ignition. something to do with the inner tumbler thingy
2006 m6 phantom black GTO:
kooks long tube headers
kooks cat-less mids
bassani cat back
ripstick
lingenfelter intake
BMR drag Bags
The Black Mongoose is offline
post #3 of 3 (permalink) Old 02-12-2015, 04:48 PM
HP11's Avatar
Quoted: 24 Post(s)
You might try graphite or dry Teflon spray. Spray some into the tumbler and work the key back and forth. Don't use WD-40 or other lubricant sprays that attract dirt and dust. If that doesn't work you might have to replace the lock cylinder as per the first post in this thread. There also a post on removing the column trim and a video:
https://www.gtoforum.com/f41/ignition...acement-29063/
HP11 is offline
Traction Control stays OFF all the time bluerex Service, Maintenance and Technical Discussion 14 08-04-2016 12:28 PM
Alternator light stays on nuggets 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-27-2011 07:24 PM
radio stays on... gtousmc Service, Maintenance and Technical Discussion 21 10-29-2010 04:50 PM
Radio stays on? socalgto05 2004-2006 GTO General Discussion 12 02-01-2010 02:31 PM
