Instrument Cluster Digital Display Problems - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-22-2014, 11:40 AM Thread Starter
Hey guys has anyone else had a problem with their Digital Display bleeding black lines in with the MPH,Volume, and the start up Pontiac logo? When I turn the car on the lines start showing up when the Pontiac shows up then the lines will go away when the mileage comes up. If I turn the volume up or down it will mess up badly until the volume goes away. Also when i switch over to MPH it does the exact same. Is the display going bad or do I have a grounding issue going on??
Thanks, Chirs
ID:	44537   Click image for larger version
ID:	44545   Click image for larger version
ID:	44553   Click image for larger version
ChitownHustler is offline
post #2 of 8 (permalink) Old 08-22-2014, 01:01 PM
It's odd that it varies with the controls. I'd at least take a good look at the wiring
post #3 of 8 (permalink) Old 12-31-2015, 07:41 PM
Are there any more posts this? My screen is just entirely filled and it doesn't change at all
LastZephyr23 is offline
post #4 of 8 (permalink) Old 02-01-2016, 04:34 AM
Send a message via MSN to Gto-noob Send a message via Skype™ to Gto-noob
mines doing this, have you figured out what was wrong?
Gto-noob is offline
post #5 of 8 (permalink) Old 02-01-2016, 09:17 PM
Same here....got my 06 back from the body shop after close to 2 months and it had this problem immediately. Any of your cars with this problem been sitting idle for a while like mine?
Whogivesah is offline
post #6 of 8 (permalink) Old 11-05-2017, 08:03 PM
mine went completely blank, I was told gm discontinued the clusters. there are shops that can replace just the center screen. they no longer make the screens but if you can find a donor cluster (ebay has em) the shop can transplant the screen.hope this helps good luck
05gtogoat is offline
post #7 of 8 (permalink) Old 01-11-2018, 11:50 PM
aircraftjack's Avatar
The small center screen in my 2006 the numbers are faded but noy on the other two screens any suggestions?
aircraftjack is offline
post #8 of 8 (permalink) Old 01-12-2018, 01:40 PM
GTO44's Avatar
Quoted: 37 Post(s)
The best way to take care of this is to send in your dash cluster to Bohnman Customs. He has a service where he replaces your malfuncting center screen with one from a salvage car. He can even change the lighting scheme while he's in there. The base cost is $125. I will be doing that soon as my center screen has been acting up lately. It's a common problem with GTO's.
Here's the link to the service:
https://www.bohnmancustoms.com/GTO_C..._17633326.aspx
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
'06 Digital Dash Center Display Fading? holdenite Interior Discussions 0 11-30-2013 12:56 AM
66 instrument cluster stevebrochu 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-09-2012 01:46 AM
64 Instrument Cluster GTOKID64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-13-2010 06:27 PM
2005 Instrument Cluster chucksgto Interior Discussions 4 12-05-2008 07:17 PM
Digital Display GTO JUDGE 2004-2006 GTO General Discussion 4 12-27-2005 06:28 PM
