Instrument panels removal and reinstall - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-21-2013, 07:56 PM Thread Starter
I have an 05 and it has had some kind of conditioner sprayed on the plastic cover for the instruments that will not come off. I found another, but I'm wondering if when I replace it all my current settings like odometer and stuff like that is stored on the cars computer system and will revert back to the right settings and readings. Also if I replace it can I just leave the ignition off to unplug it and plug it back in instead of unhooking the battery. Not sure if it is true that if you lose the battery contact that the code for the key will no longer be good. Thanks for any help
BoiseLS2 is offline
post #2 of 4 (permalink) Old 08-22-2013, 09:02 PM Thread Starter
Help a Brother out !
No one ?
BoiseLS2 is offline
post #3 of 4 (permalink) Old 09-01-2013, 11:44 AM
Unhooking the battery only affects learned fuel trims which will relearn in short order. I believe the odometer values are stored in the cluster so I think you would lose them. You need to use a '05-'06 cluster tho for your car. The VIN numbers will not match
post #4 of 4 (permalink) Old 09-03-2013, 06:40 PM Thread Starter
Ended up not needing it, but it is for sale on Ebay now.
BoiseLS2 is offline
1966 GTO instrument cluster removal and reinstall hwilliams15 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 04-18-2013 01:29 PM
Instrument cluster removal RGT Interior Discussions 5 11-09-2012 04:30 PM
Reinstall Delco PB AM radio wiring redgoat67 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 04-30-2012 08:08 PM
Instrument cluster removal on 67 billcocarb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 11-15-2011 09:33 PM
Removal / Reinstall of silver steering wheel spoke covers. Help please! stephen77375 Interior Discussions 1 10-26-2011 10:28 AM
