mats? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 08-11-2011, 11:45 AM Thread Starter
nicayotte's Avatar
mats?
My GTO did not come with front or rear car mats, I know Lloyd makes a set but doing some searching I did not find anyone who owns a set. Anyone got some pictures or know of another good source for some mats. I am looking for the closest thing to stock.
05 GTO - Midnight Blue - SLP Loudmouth 1 - lingenfelter air intake
nicayotte is offline
post #2 of 16 (permalink) Old 08-11-2011, 07:22 PM
chilliwhiggerE's Avatar
Location: Hollywood, Florida originally from Pittsburgh, Pa.
I got the Lloyd mats embroidered with the GTO on them. They are really nice but $115 for the 2 fronts was a little outrageous. They fit a lot better than the stock mats and came with hold down hooks.
chilliwhiggerE is offline
post #3 of 16 (permalink) Old 08-12-2011, 01:21 PM
srs7324's Avatar
I have the Lloyd front mats embroidered with the GTO and the rear they supply as well, but the the mounting holes do not line up like the OEM do.
The mounting hole is about 2 inches too far forward, and if I use it they cover my seat mounts.
I kept my OEM black front and rear mats just in case as well as the locks.
Pictures of both attached.
ID:	12006   Click image for larger version
srs7324 is offline
post #4 of 16 (permalink) Old 08-12-2011, 11:29 PM
The mats I got have the offset holes as well but the provided hooks are offset as also. IMO you should contact Lloyd and get their hooks. I believe they may have discovered a flaw in the factory design and made them that way purposely to improve their performance.
post #5 of 16 (permalink) Old 08-14-2011, 01:08 PM Thread Starter
nicayotte's Avatar
My car has neither the hooks, mounts or mats!
BTW i love the look of those GTO mount, really want them!!!
post #6 of 16 (permalink) Old 08-14-2011, 03:52 PM
I've got the rubber mats by Lloyds. They are the same way, they gave me some "S-hooks" that clip into the hole and then the mats sit on the hook. I don't use them.
LS2 MN6 is offline
post #7 of 16 (permalink) Old 08-14-2011, 03:54 PM
If you REALLY want the stock mats, I might be willing to part with mine I don't think I'll ever use them.
LS2 MN6 is offline
post #8 of 16 (permalink) Old 08-14-2011, 06:05 PM
srs7324's Avatar
I have been wanting a set of these for sometime, but I got my Lloyds from another GTO owner so the S hooks were not provided.
Today I made an 2 inch adapter for the driver side and the GTO locks worked perfectly, the passenger floormat was not as bad, so it fit and locked with a small adjustment.
Since Lloyds states this are custom made I would expect a perfect fit and not have to depend on adapters, hooks or workarounds to get them to lock in place.
All I need now is find someone wanting to part with a Lloyds GTO trunk mat.
srs7324 is offline
post #9 of 16 (permalink) Old 08-14-2011, 06:44 PM
You would think that custom made means they line up the holes, but I think the stock GTO grommet system doesn't work on their mats, and they didn't want to engineer new grommets. My "s-hooks" where actually Toyota Service parts (for the latest recall of the floor mats). Seriously!
LS2 MN6 is offline
post #10 of 16 (permalink) Old 08-15-2011, 07:47 PM
srs7324's Avatar
I have the custom GTO stainless locks sold on Ebay, you can paint or clear coat them however you like.
The lock on the end is held on by a screw so remove it, with the locks off insert into floormat hole and install lock back on with screw and it is done.
I had to use 2 of my set of 4 locks just to make the driver floomat work.
One for the floormat to attach to the adapter plate and a second to attach the adapter plate to the mounting hole in floor.
srs7324 is offline
GM aftermarket Mats LaPuzza Interior Discussions 4 05-06-2008 09:32 PM
Floor Mats GTO JUDGE Interior Discussions 4 08-12-2006 10:19 AM
Rubber Mats oldgoat Interior Discussions 5 03-24-2006 07:40 PM
Floor Mats GTO JUDGE 2004-2006 GTO General Discussion 5 10-05-2005 04:29 PM
Floor Mats Monte 2004-2006 GTO General Discussion 9 10-31-2004 08:44 PM
