Need electrical help for an 06 - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-30-2014, 11:17 AM Thread Starter
Ever since I bought my 2006 GTO last summer, the electronics have been acting up. It normally only happens when I drive for the first time that day, and normally only occurs when im shifting through the first 3 gears. The electronic system (dash, radio, headlights, everything) seems to reset. It will shut off for maybe one second and then kick back on. It doesnt always do it, and it seems to happen randomly. Does anyone have any insight on what this might be. I just bought a new battery. I just dont want this being an ongoing issue. Any help would be appreciated. Thanks!
clarkr11 is offline
post #2 of 8 (permalink) Old 01-30-2014, 07:18 PM
teds06goat's Avatar
Hey Just a couple of questions? Do you still have or did it come with a warrenty? If it did take it in ASAP! If not try looking at your BCM mounting location, it might be loss or not completely plugged in maybe? Also look and wigggle all of your connections to make sure everything is firmly plugged in. The BCM is located under your glove box, also while your there check all the wires plugged into it. The goats are known to get Chaffed wires there as its rubbs againts the metal supports. Maybe your instrument cluster was removed sometime ago and wasnt install properly? I would do a full wiggle check of the car just in case. But remember just once! Or else your just playing with it. lol
I hope that helps, and good luck.
Thanks HP11 you are correct.
Last edited by teds06goat; 02-01-2014 at 01:50 PM. Reason: Corrected from ECU to BCM
teds06goat is offline
post #3 of 8 (permalink) Old 01-31-2014, 09:32 AM
HP11's Avatar
Quoted: 24 Post(s)
That would be the BCM (body control module) not the ECU.
HP11 is online now
post #4 of 8 (permalink) Old 02-01-2014, 09:24 AM
jpalamar's Avatar
BCM wires are probably chaffing.
04 GTO - sold
jpalamar is offline
post #5 of 8 (permalink) Old 02-05-2014, 04:53 PM Thread Starter
Thanks!
Thanks for your help guys! I'll check it out as soon as I get a chance. Snow and ice in KY is killing me.
clarkr11 is offline
post #6 of 8 (permalink) Old 02-07-2014, 12:07 PM Thread Starter
Still no luck...
The BCM seems to check out. Wires weren't chaffed. I just had another run-in though. This might help narrow things:
I wasn't getting power from the battery today for awhile, and when i popped the hood to take a look at the battery cables, they were secured to the terminal correctly. BUT, when I wiggled the cable itself, it caught power and the car alarm started to go off. It was fine after that. Do you think the issue would be in the battery cables instead of the BCM? I don't own a garage or anything so I can't really get into it very much. Way too cold outside to tinker and look deeper.
clarkr11 is offline
post #7 of 8 (permalink) Old 02-08-2014, 06:33 AM
silversport's Avatar
if they were loose...yes...or corroded...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #8 of 8 (permalink) Old 02-19-2014, 10:06 PM
pocketmaster's Avatar
Disconnect your battery and clean the terminals.
God Bless Billiards!!!!
pocketmaster is offline
Need some help with electrical problems Jmckinney1991 Interior Discussions 5 10-02-2013 07:35 AM
Another electrical ????? 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 08-22-2011 05:56 PM
69 electrical problems JJs69GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 07-06-2011 12:34 PM
Electrical Problem steve5000k 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-11-2011 03:47 PM
Electrical Gremlins? Khammy87 Interior Discussions 6 01-26-2011 07:21 PM
