New Key Programming - Pontiac GTO Forum
post #1 of 11 (permalink) Old 09-14-2014, 08:30 PM Thread Starter
New Key Programming
So a little while back I lost one of my keys to the car. I don't drive the car hardly at tall and today I pick up the other key and notice the trunk button has completely busted through. I'm going to buy a new case from Gm because it's about $80 bucks and swap the guts. Is their anything I can do with the new old case and new components to at least program the remote to lock and unlock with out paying the dealership.
handicapped center is offline
post #2 of 11 (permalink) Old 09-15-2014, 06:48 AM
HP11's Avatar
Quoted: 24 Post(s)
https://www.gtoforum.com/f3/key-fob-t...ramming-18209/
HP11 is offline
post #3 of 11 (permalink) Old 09-15-2014, 08:03 AM Thread Starter
Great. Thank you very much.
post #4 of 11 (permalink) Old 09-15-2014, 08:05 AM
AlaGreyGoat's Avatar
Don't quite understand the question, but if you just need a case:
Uncut New Smart Remote Keyless Key Fob Replacement Case Shell for GM Pontiac GTO | eBay
$80.00 for a case only, is robbery.
Replacing the case shouldn't need any programming. If it does, you SOL.
You can't reprogram a used key.
If needed, you can get a NEW replacement fob and program it as per HP's link.
A new fob from the dealer should be around the $80.00 price. OR:
2004 2006 Pontiac GTO Remote Control Transmitter Key Fob New 92123129 | eBay
Larry
AlaGreyGoat is online now
post #5 of 11 (permalink) Old 09-15-2014, 08:19 AM
Also, I've had my remote act up and not function correctly. I put it in the ignition and pushed the buttons a few times and removed it. It
then, works correctly.
Larry
post #6 of 11 (permalink) Old 09-15-2014, 09:07 AM Thread Starter
I'm trying to use the new FOB but program the uncut key is the idea, so I can lock and unlock the car. Thank you for the help.
post #7 of 11 (permalink) Old 09-15-2014, 12:53 PM
HP11's Avatar
Quoted: 24 Post(s)
You can't program the remote without being able to put it in the ignition and turn it to the different positions. Have the key cut by a locksmith and use the procedure linked above to program the remote.
HP11 is offline
post #8 of 11 (permalink) Old 09-15-2014, 12:54 PM Thread Starter
Will a regular lock smith do that kind of work? I thought only the dealer ship can do that work.
post #9 of 11 (permalink) Old 09-15-2014, 12:59 PM
HP11's Avatar
Quoted: 24 Post(s)
A locksmith that has the capability/equipment to cut center cut keys can do it. I've had them done by a locksmith. I spend very little time at the dealership with any vehicle once the factory warranty has expired.
HP11 is offline
post #10 of 11 (permalink) Old 09-15-2014, 01:44 PM Thread Starter
That's a good Idea. I'll check around, the dealership is ridiculous for a new key.
programming issue mbmGTO 2004-2006 GTO General Discussion 2 08-05-2012 01:25 PM
key programming issue??? gtoshayan 2004-2006 GTO General Discussion 5 09-20-2011 05:13 PM
Re-Programming The BCM CWKSF 2004-2006 GTO General Discussion 0 04-30-2009 07:46 PM
Key FOB Transmitter Programming GM4life Service, Maintenance and Technical Discussion 0 09-27-2008 09:00 AM
