Noise intrusion thru shifter boot - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-16-2014, 09:21 AM Thread Starter
1st thing I noticed upon driving home new/used 05 was amount of noise coming thru shifter. I can make it noticeably quieter by simply wrapping my hand around boot. I may end up upgrading shifter, is their any room under there for a little insulation? Thanks, Tom
groundcontrol is offline
post #2 of 3 (permalink) Old 05-16-2014, 10:27 AM
BWinc's Avatar
Sounds like you might already have a non-stock shifter and the vibration is traveling through the shifter knob, making it rattle because it wasn't re-installed with enough RTV in it. There is plenty of room for insulation.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
post #3 of 3 (permalink) Old 05-18-2014, 08:12 PM
I agree. I'd first look to see what you have there. The stock shifter was mushy but quiet. If it's an aftermarket there are different things you can do depending.
B&M Shifter Boot 69-er Service, Maintenance and Technical Discussion 5 02-17-2012 10:31 AM
Shifter Boot tiemann Interior Discussions 1 09-14-2009 02:33 PM
A lot of heat and road noise coming from around boot area of shifter goatfan2004 Interior Discussions 8 06-26-2009 10:59 AM
shifter boot badtmpdgoat Service, Maintenance and Technical Discussion 11 01-24-2005 09:59 AM
