odometer froze - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-20-2013, 03:33 PM Thread Starter
odometer froze
The odometer on my 06 gto stopped working. All other parts of the cluster work properly. speedometer and even the trip distance still reads... any ideas to what and how to fix this. thanks
elest05 is offline
post #2 of 7 (permalink) Old 07-20-2013, 05:47 PM
jpalamar's Avatar
Miles are saved in the cluster so I'd bet you have a bad clutster.
04 GTO - sold
jpalamar is offline
post #3 of 7 (permalink) Old 07-21-2013, 06:41 AM
I don't have a "new" GTO but on my Ford truck the odo stopped working shortly before the alternator failed.
On late models since everything is electrically powered even a slight drop in voltage can cause things to go haywire. I would check battery voltage and alternator output first.
post #4 of 7 (permalink) Old 07-21-2013, 09:44 AM Thread Starter
Yeah that would be unfortunate. It stopped right after I changed my oil and had it tuned.
elest05 is offline
post #5 of 7 (permalink) Old 07-21-2013, 09:47 AM Thread Starter
Ill check the voltage and all that to be sure thanks. Might have to make a trip to dealer
elest05 is offline
post #6 of 7 (permalink) Old 07-21-2013, 05:50 PM
jpalamar's Avatar
Also check the BCM wires in the dash. They can fray and do crazy things. If you search the forum you can find tons of good into about this common issue.
04 GTO - sold
jpalamar is offline
post #7 of 7 (permalink) Old 07-22-2013, 05:46 PM Thread Starter
Also check the BMC wires in the dash. They can fray and do crazy things. If you search the forum you can find tons of good into about this common issue.
Will do. Thanks for the help
elest05 is offline
Odometer Help Please Star 2004-2006 GTO General Discussion 4 04-11-2013 03:23 PM
3.91 Gear Ratio odometer error firebird Drive train, suspension, alignment and brakes. 0 05-10-2012 10:15 PM
Normal for odometer and radio time to still be visible while car is off?...... pctek 2004-2006 GTO General Discussion 4 05-05-2011 03:04 AM
70 GTO Odometer Gear GTO JUDGE 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 03-24-2009 08:41 PM
